0
0
Quick chassis dolly spacing ?
I am finishing my chassis dolly and need to know the space I should leave for the main chassis tubes. I believe the tubes are 20" on center but do not know outside total dimension. I guess if they are 4" tubes the outside is 24" but I don't want to make an assumption .
Thanks.
Kit due @ 8th of August
24 on center of tubes, so 20 between.
Here are the plans I used:
http://thefactoryfiveforum.com/showt...ferrerid=13456
I did decide to make the dolly only 28 inches total in height. The original height was a little high for me.
Good luck! Post pics when your done!
Thanks. Looks like I need at least 28" with an extra two inches for the space between blocks on top of my dolly.
- You may not post replies
- You may not edit your posts
Forum Rules
