Setup: 302 with factory EFI, AOD transmission, A9L, RF wiring harness, GPS speedometer.
1. With the GPS speedometer my first impulse was to plug the VSS hole in the transmission, but won't the ECU require this output? Will the speedometer sender plug in the RF harness also route the VSS signal to the ECU?
2. The RF harness seems to have wiring for the clutch safety switch, but so far I haven't found wiring for a NSS on an auto trans (hit me in the head with it if I've missed it). In the absence of specific wiring for the NSS, can the clutch safety switch wires be rerouted to pins 3 and 4 of the NSS on the transmission?
