0
0
injector harness
I am having trouble finding connectors for the fuel injectors on my 03 donor engine. the r/h side had deteriorated to the point that they were no good. I called Subaru and they said that there was nothing offered. I have been to the wreckers several times but have not found a turbo car. apparently the 03 turbo is different than the N/A ones. anyone have a couple laying around?
I would check ebay you can probably get a whole engine harness
I have tried some ebay stuff, I have enough of the wrong stuff already. visually it is hard to tell the n/a stuff from the turbo stuff
I have an 02 engine harness if there the same?
Have you tried injectorrepair.com? They have a page with pictures of most of the connectors that are out there.
Thanks Jamie they had them.
