2002 (2nd generation)
FFR Extras:
3 link rear suspension assembly
Body cutouts
FFR Hilabrand type, non-pin drive, 17" wheels
Aluminum fuel cell
Additional Parts:
Ford Racing 8.8 rear end assembly installed with springs and shocks
Ford racing 11.75" rear brake kit with emergency brake cables installed
Bear 13" front brakes (slightly used) installed with all brake lines and rear brake bias
Mustang pedal assembly with single dual pressure master cylinder installed and plumbed
Aluminum radiator and fan installed
Complete gauge set installed in dash
Front upper and lower tubular control arms installed
Front wheel spindles installed
Steering rack with upper and lower shafts with two SS u-joints installed
About 85% of aluminum installed, some with Dynamat
Battery box, battery cables all installed
Bump steer kit installed
Starter solenoid installed
Fuel lines, fuel filter, holly fuel pump and regulator (carb) installed
This a value of about $26,000.00 plus the assembly to date. Asking $19,500.00. Delivery is free within New England.
Please don't let the age discourage you. It has been covered in a heated garage its whole life.
Will trade for a 33 Coupe kit!
Ryan
