0
0
WRX Transmission woes- 5th gear syncro gone
Well this sucks. Took it out for a nice spin to the car show and now I can't get the thing into reverse. I was having a hard time down shifting from 4 to 3rd and it wouldn't stay in 5th. I've tried everything to get it into reverse. Even manually without the linkage. Think I'll have to crack the case open? I've read everything from reverse check sleeve to bent shifter fork. Ugh.
Do you have an idea of how much torque your electric motor is making? Since it is full torque right away the trans may not be strong enough VS a gas engine that builds torque.
It's making 185 lb/ft from 0-5000 RPM. What would it have broken or worn out so quickly ?
Originally Posted by
ehansen007
Till you open it up it is all just a guess.
Do you know the history of the trans?
Someone else mentioned it wouldn't stay in gear and the culprit was the locking sleeve and rear nut weren't torqued well enough.
ehansen007
My other theory is that the lack of oil in the rear of the case (due to my angle of install) heated up the syncro so much, it expanded the nut, negating the dents and spun off. From this photo you can see that there is no oil on the syncro and that it appears to have had some heat issues.
Is it possible the center diff would sling oil up onto the fifth gear synchronizer?
Maybe we need to add a arm to the 2wd adapter that will sling oil to the top of the case.
This little oil catcher in top the case sends oil to the center of the input shaft. Does anyone know where that oil goes?
The center diff displaces a ton of oil, I think it is very important to have the proper amt of oil...
RM1SepEx
With my car level, the center diff was only 1/4" deep into the oil.
ehansen007
One thing I noticed on both transmissions is that when I pulled off the tail housing, the bearing races were sitting there. This is something most builders are not going to think about when removing the center diff assembly (like me) and that is that center diff has a race at the back end of the case that will not come out on it's own but apparently with some heat it releases. It looks like it will just sit in the tail case without entering the 5th gear area but why take the chance? I've pictured it below.
Definitely a good idea to remove that race. I didn't notice it at first either but it fell out when I was handling the rear housing.
STiPWRD
Actually, you should remove the race and the big bearing below it. They both fall out.
Another thing I noticed is that there is a hole that flying oil would go into to lube the shifter shaft.
Without the center diff, this won't happen. I am going to put some red grease on the shifter shaft.
Nothing like the ole "aerosol overhaul!!!" Let's hope she better than the last.
FFR MKI Roadster FFR2202K Built in 2000 sold
FFR Hot Rod #39 under construction
- You may not post replies
- You may not edit your posts
Forum Rules
