Thanks Thanks:  3
Likes Likes:  15
Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 315
Thread: My 818R Project has arrived
  1. #121
    Bowling Green, KY
    Nope, I am not going to cut any more holes in the front fascia at least to start with. I don't think I will be having brake temp issues with the AP brakes I am using, If I do I will add some additional ducts for them.
  2. #122
    Kirkland, WA
    And I am sure about 30 more 1o minute jobs that will need to be added to my work list.
    That is at last another 2-3 weeks as it's those 10 min jobs that take 2-4 hours each
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  3. #123
    Looks great! I disagree on the more holes up front for now, easier to take away material later than to add. With an aftermarket rad and sealed ducting, can't see the need for more air. Our brakes are fed from the bottom splitter, will post new pics now that they have been cleaned up.
  4. #124
    Clovis, Ca
    I never needed any brake duct holes up front either. Its a damn light car for the size of brakes. If anything, heating them up for the pads took longer (race pads).
    Thanks- Chad
  5. #125
    Bowling Green, KY
    Good day today crossed a few 10 minute jobs off the list, doors fit and installed and the rear wing mount is fabed up. To finish the wing mount I just need to drill the holes for the wing struts and weld on the clevis's to the chassis for the rear struts.
    Will take a few shots of the wing mount tomorrow.
  6. #126
    Bowling Green, KY
    Wing mount complete, tabs welded on the chassis and aluminum struts ordered.IMG_2085.JPGIMG_2086.JPG
  7. #127
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Nice, the mount looks very sturdy
  8. #128
    Kirkland, WA
    Side sails look good, glad to see you got them opened up.
    Does the wing support have any vertical support, hard to tell from the picture ? Are you running the GTC300 wing ?
    Tony Nadalin
  9. #129
    Bowling Green, KY
    Hi Tony, Yes the wing mount has vertical support from the back chassis right next to the trans mount. I welded on 2 3/8 clevises the chassis and 2 clevises on the bottom of the wing mount. I am using swedged R&L hand threaded aluminum tubes with 3/8 rod ends for the struts, ordered tubes today from Speedway. I now have the rear fascia removed and will take a picture with the struts installed when they arrive. The clevises and other tabs I buy from A&A Manufacturing, great resource if you haven't used them.
    I used 1" .049 Chromalloy tubing for the wing mount frame, I am happy with how light it is.
    The wing is APR wing that FFR was selling with the R kit when I ordered it back in June of 2013.
  10. #130
    Bowling Green, KY
    Templates made for fuel cell firewall along with a few other 10 minute jobs.
  11. #131
    Looks good Mitch,
    I'll see you in 2 weeks if the weather cooperates and we get the car back together.
    Are you going to be ready to run?
    Bob and Mike.
  12. #132
    Bowling Green, KY
    Bob, fingers crossed on the weather, I have a good feeling we are due for a nice weekend. No the my car won't be ready, we are headed up to Minniapolis next weekend for our grandaughters 4th birthday.
    Still about 30 items on the list to finish up and I have get get the car to the dyno sometime soon.
    The brake rotors are only 299mm 72 vain AP rotors the AP calipers are a compition set up for a BRZ. Saves close to 9 lb a corner I will be suprised if I go through pads and rotors.
  13. #133
    south-central CT
    Hi Tony, Yes the wing mount has vertical support from the back chassis right next to the trans mount. I welded on 2 3/8 clevises the chassis and 2 clevises on the bottom of the wing mount. I am using swedged R&L hand threaded aluminum tubes with 3/8 rod ends for the struts, ordered tubes today from Speedway. I now have the rear fascia removed and will take a picture with the struts installed when they arrive. The clevises and other taps I buy from A&A Manufacturing, great resource if you haven't used them.
    Speedway has lots of cool stuff, like this Gusset Kit/Tab Kit, 60 Piece (which I have and think is a bargain) but I just can't find anything easily. One of the worst sites to search on I have ever been on. Perhaps the thing to do is call them...
  14. #134
    Clovis, Ca
    For more weld on type tabs, just about anything you can think of. https://www.tabzone.com/
    Thanks- Chad
  15. #135
    Bowling Green, KY
    Scargo, Speedway is one of my go to places.
    Chad, thanks for the tip on the Tab Zone, they are more expensive than A&A but have some stuff A&A doesn't have.
  16. #136
    Kirkland, WA
    Nice job !
    Tony Nadalin
  17. #137
    Bowling Green, KY
    More steps forward and fewer steps backward this weekend. I believe the rear quarter fenders and rear fascia has had its final install. Now that I think about it the rear fascia will come off again to install the Zero DB Shift linkage. (Note to self add to the list)LH Side installed.JPGLS Body Install.JPG
    Fuel cell and Firewall installed for the final time.
    And Muffler and exhaust is finished other than the exhaust hanger.
    Next up finish radiator ducting and mount front splitter. Other than the first start and go kart crossing more things off than I am adding to the to do list is a really satisfying part of the project.
  18. #138
    Kirkland, WA
    Mitch, looking really nice ! I feel your pain on the steps forward and at the same time steps backwards as I work on the car and don't see any real progress as a mater of fact sometimes it looks worse and like I have undone the previous weekends work.
    The side sails look great.
    Have you fitted all the under the body aluminum yet ?
    Tony Nadalin
  19. #139
    Very nice!
  20. #140
    Bowling Green, KY
    Tony,
    Looks like you are getting really close.
    At this point in the build though more stuff is going on the car and staying on which is a great feeling. I just started on my templates for radiator inlet and exhaust sheet metal. I do have the Aluminum installed under the battery tray, I want to get the splitter and radiator ducting done before I finish the rest of the front sheet metal. I haven't even started to think about the under engine panel or diffuser, but the are on my list.
  21. #141
    Bowling Green, KY
    A few hours in on the car today and a few more 10 minute jobs off the list.
    Firesystem installed and plumbed.
    And muffler/tail pipe support completed.
  22. #142
    Kirkland, WA
    I love those 10 min job, as I wasted a day doing the windscreen, which I thought was going to be 30 min max.
    Looking good on fire system, and exhaust.
    Did you do anything to hold the front of the dash to the windscreen mount or did you just let it sit there between windscreen and mount ?
    Tony Nadalin
  23. #143
    Bowling Green, KY
    Hi Tony,
    Thanks it is fun watching the list shrink.
    Not sure I understand your question.
    I used nut plates and 10/32's to hold the windshield to the fiberglass 2 10/32's up front to the chassis. 6 10/32's and nut plates hold the front of the dash to the fiberglass with 4 10/32's under the back of the dash.
    Not sure if I answered the question or added confusion.
  24. #144
    Bowling Green, KY
    My rocker block out panels.
  25. #145
    Mitch
    I covered mine with heat shield material to prevent engine bay heat from moving into the side pods.
    how did you indent the metal to make it stronger?
  26. #146
    Bowling Green, KY
    Bob, I used my stepsons bead roller.
  27. #147
    Kirkland, WA
    Very nice ! So do the block out plates come with the kit or did you make them (I have a pile of aluminum left that I have not looked at yet) ?
    Tony Nadalin
  28. #148
    Bowling Green, KY
    Tony, I they don't come with the kit, I just made a template and transferred it to the aluminum and cut them out. Just made one template that works for right and left with little minor trimming.
  29. #149
    Kirkland, WA
    OK, thanks will look at doing the same
    Tony Nadalin
  30. #150
    Bowling Green, KY
    Got some shop time today and finally decided to cross off bumpstreeing the car off the list. The front took some time but got it with .007" over 3 inches, 2" in compression 1" drupe.
    the rear came right in .005 on the right rear and .008 on the left rear.
    It is was closer than I expected and really no hassel. I must say I had been dreading the process not knowing what to expect, I am really pleased with the out come.
    OK I have to get motivated to finish the radiator and intercooler ducting.
  31. #151
    Bowling Green, KY
    Installed the Zero DB shift linkage, bolts right on. Thanks Craig.IMG_2191.JPGIMG_2192.JPG
  32. #152
    Boy, that looks great!
  33. #153
    Mechie3's Avatar
    That's what I like to hear.
    Zero Decibel Motorsports
  34. #154
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    Finally settled on a location for my AOS and KB oil control valve.
    Attachment 48570Attachment 48571
    Thanks for the heads up on your wet sump plans Mitch.
    Do you have any more details about the Killer B Oil pan? How low does it sit in the car?
    What's the Saker Sportscars baffle look like? How is it better than the OEM or Killer B baffle?
  35. #155
    Bowling Green, KY
    It sits about 1/2" below the frame rail on my car, my JDM header is about the same. Like the Cosworth baffle the Saker baffle sandwiches between the block and pan but a simpler device compared to the Cosworth piece. The idea is to not allow the oil climb the side of the pan and fill the heads in high G corners. Emailing a few Saker owners and talking to the folks at Saker reports have been good, the Saker is capable of 1.7g + I am told. Anyway worth a try.
    I tried to buy one from Saker but no luck so I am making a few myself and will have it on track soon. I am logging oil pressure and temp and looking forward to seeing if the results.
    As I mentioned Tony I believe is using or planning to use the Cosworth pan and baffle set up so we should be able to compare notes.
  36. #156
    Bowling Green, KY
    Got some some car time in yesterday, made up my cold air box.
  37. #157
    Sgt.Gator's Avatar
    Bend, Oregon
    Nice!
    Owner: Colonel Red Racing
    818R ICSCC SPM
  38. #158
    Bowling Green, KY
    Don't know why but have been procrastinating on finish fitting and installing the hood pins for engine cover and rear deck, it is now crossed off the list.
  39. #159
    Looks Good! Your are getting closer for sure.
  40. #160
    Bowling Green, KY
    Really now I am waiting on my tires (BFG R1S) and of course the rears are back ordered until late June Early July. So I have some time to finish and tidy up some details and get it to the tuner.
