0
0
WTB Front Inner CV joint for WRX, '02 to '04
One of my front axles was a replacement that has a front inner CV joint with different internal spline size from the stock WRX, so it won't fit on the FFR axle.
Does anyone have one to sell? Or a suggestion for the best alternative solution to putting an 818 axle together without the donor axle?
I already picked up an axle from Advance Auto, but its splines don't match either (so I wasted $60 by taking it apart).
I have a few extra. I will snap a picture for you and if you like it take care of the shipping
Thanks, Brando. I appreciate it.
I found replacement inner CV joints--just the joint and no axle--on Amazon. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I needed to replace the aftermarket one that came on my 2006 WRX donor. It fit the axle and seems well made.
I tried the same company for the outer CV but with no success. I could not locate the Subaru part number for this. As far as I can tell, the outer joint is sold together with the shaft.
John - the part you linked appears to be the version with male end going into the transmission. I believe 2002-04 requires the inner CV joint to be the female, since the stubs stick out of the transmission. Great reference point though for those with later year donors.
- You may not post replies
- You may not edit your posts
Forum Rules
