Results 41 to 80 of 88
Thread: Building an 818R in Mt Pleasant, NC
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    I love that you are keeping track of the hours spent. We are too and it has been interesting!
    Our OEM radiator is about 1" too tall too. We are going to make a spacer.
    Tamra
    First autocross 3/29/15
    Mar 2014
    Mount Pleasant, NC
    Day 19 Total Hrs: 88
    Spent most of the day on detail work, drain plugs, brake and clutch cylinder work and finished the cooling hoses. Started installing the interior, seats, and electrical connections.
    My son sat in it to try it on for size - we might have to remove the fuel tank to get the seat back far enough, wish there was another 6" of room lengthwise and 2" width.
    Clovis, Ca
    Quote Originally Posted by wildhorsesracing View Post
    IMHO: I believe it to be safer than many new car factory tanks. I have raced for 20 years and can vouch that I have seen many tank installations that were far worse than this. In NASA the tank is legal if it is an OEM tank from the manufacturer, this is the OEM tank from Factory Five. With the structure of the cage in the 818R I believe it will take a massive hit to get to the tank.
    I also have first hand experience with a fuel fire on track:
    https://www.youtube.com/watch?v=shg92VqoSYY
    I will emphatically state that you should always wear ALL of your safety gear whenever you are out on track. I had everything but my balaclava on that day and the 2nd degree burns on my neck & chin proved that I shouldn't have skipped that piece.
    FWIW: most of the sanctioning bodies approve cars with OEM tanks, even the newer cars with plastic tanks. The Porsche in the video had a factory plastic tank.
    That begs the question, If you have first hand experience with a fuel fire, why not just put a fuel cell in? Why even risk it?
    Thanks- Chad
    Mar 2014
    Mount Pleasant, NC
    Because I have seen fuel cells burst as well, so I don't feel that the extra effort is worth it. Besides in the 20 years and 50 or so cars that I have raced competitively that was the only wreck I have ever had. If you feel the extra effort is necessary, then by all means, go ahead and install one. But the fuel tank included with the car is encased inside the cage, I would be highly surprised if anything could impact the car hard enough to get to it.
    Mar 2014
    Mount Pleasant, NC
    Day 30 Total Hrs: 92.5
    Worked on the TGV delete plugs (thanks Wayne @ VCP), installed the driver's seat and rest of the firewall. Also installed the kill switch for racing.
    Clovis, Ca
    I'm not in agreement with that, but it is your car.
    Have you thought about the fuel starvation the stock tank will provide in corners?
    Thanks- Chad
    Mar 2014
    Mount Pleasant, NC
    Haven't thought about that - if it becomes an issue then we'll look at adding another fuel tank. We'd like to take passengers but after mounting the seat we are thinking that we might have to forgo that because it is too tight, we could sure use the legroom if the tank wasn't there.
    south-central CT
    One builder modified his gas tank.
    Hard for me to say whether gas will leave the bowl to the extent that you could get starvation. FFR never ran a stock tank. I do turns where high G's last for 10-12 seconds. I know foam would help sloshing. I stuffed a 8 x 8 x 4 piece of fuel cell foam through about a 3" diameter hole in my STi's tank.
    As to safety, To say that incidents are rare is like saying you didn't get lung cancer from smoking. Production cars are crash-tested, too. The 818 is not. To me, this is a big loop-hole that allows an untested configuration to race.
    As we know some production cars are not necessarily up to the task in a high speed crash event. Still, this is what some racing orgs will allow, I assume, based on a cars approval by the NHSTA and frontal crash test FMVSS 208. How many times have we seen horrible racing crashes where a rear-ending is involved? In the case of a rear or rear-side impact I now am quite concerned about my STi gas tank vulnerability.
    Mar 2014
    Mount Pleasant, NC
    I think my tank has a bowl like that already, I remember having trouble getting the fuel pump installed because the filter on the end was hitting the sides of the internal bowl
    Has anyone come up with an alternate fuel tank location that doesn't consume the passenger seat area?
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    MSD had a fuel pick up blanket on display at PRI that was hooked to a pump with 8 oz of fuel in the tank plus what was in the lines and was pumping a steady stream. The return was hitting the blanket and the fuel hitting the blanket was enough to keep the pump fed.
    south-central CT
    Is this part of it? This from MSD/Atomic EFI. Having trouble finding anything related, re, MSD. Sounds like a great idea.
    Administrator
    Enterprise Alabama
    It may have been Holley
    Exeter R.I
    Looks interesting
    Administrator
    Enterprise Alabama
    San Diego Ca 92106
    ^ wow another must have item! Thanks Wayne, the budget keeps creeping higher.
    Administrator
    Enterprise Alabama
    No problem, glad to help
    Mar 2014
    Mount Pleasant, NC
    Total Hrs 108.5
    It's been a while since I posted, been busy with many things and even managed to go on vacation. Been waiting for a few things, new fuel tank, wiring harness and axles.
    Mar 2014
    Mount Pleasant, NC
    Total Hrs: 111.5
    Got the wheel spacers in the mail yesterday so I installed them, sat in the car and made racecar noises!
    Decided to rotate the turbo to make it easier to plumb and/or add a larger intercooler.
    Apr 2014
    Shelton, CT
    Total Hrs 108.5
    Were you able to fit your brake and clutch cylinders without cutting the plastic surround?
    Progress looks great!
    Tamra
    Mar 2014
    Mount Pleasant, NC
    Yes, but we cut the plastic dash to make it easier to fill and see. We added a plexiglas window on the front of the dash and plan to put a hinged door on top. You can see the opening and the reservoirs in this image:
    Bowling Green, KY
    Just met with the Holley folks last week, the fuel sock will be available in March. I will be getting one to try in the stock tank.
    Car is looking good Jim.
    Mar 2014
    Mount Pleasant, NC
    Total Hrs: 117.5
    Moved the turbo up a few inches to clear the intake manifold with some 1.75x.095 tubing. Much easier to plumb now and eliminated the catalytic converter that feeds the turbo.
    Exeter R.I
    Are you making a cutout in the engine cover? Cause your pretty close to it now.
    Mar 2014
    Mount Pleasant, NC
    I test fitted the cover and the second (passenger) hump gives me plenty of room - 4-6" of clearance, unless the engine cover needs further clearance to fit the rollbars.
    Mar 2014
    Mount Pleasant, NC
    FWIW: we have been seriously considering modifying the rear deck cover anyway, we want to put an air-to-air intercooler in the rear bumper and feed cool air to it via a scoop a la "ariel atom style"
    Exeter R.I
    That would be cool, and if I built an R I would have done just that, but maybe twin inlets on top of the humps with an air box under the cover directing air to the IC positioned right before rear facia.
    south-central CT
    I'm thinking that the (passenger) hump gets bigger and feeds the intercooler. Remove the R windscreen on that side and perhaps even enclose the passenger side (no passenger) making for a smooth flow into a scoop.
    That is the way FFR blue car intakes air.
    Mar 2014
    Mount Pleasant, NC
    Total Hrs: 119
    WOW! How time flies! It's been over a month of waiting! We've been waiting on a wiring harness , axles that fit and a gas tank that allows folks who have inseams longer than 28" to drive. The gas tank and new firewall arrived this week so we started the process of test fitting it:
    We had to move the routing for the shifter cables. Axle place says we'll have axles this week, they had a helluva time matching subaru axles with the proper ends/splines/cages/etc., then all we are waiting for is a Megasquirt wiring harness from Wayne @ VCP.
    We'll start the process if installing the bodywork to kill time while waiting for the wiring.
    Administrator
    Enterprise Alabama
    Jim, I have more MS3"s coming, your harness is done except for the ECU wiring
    Bowling Green, KY
    Jim,
    When are you targeting for your first track test?
    Syracuse, NY
    ... I have more MS3"s coming ...
    Wayne - Do you have a DBW module for MS3's so we can use 06-07 donor motors without changing to cable throttle yet?
    MK3.1 Roadster completed 2011
    Administrator
    Enterprise Alabama
    They have a some prototypes they are testing but no release date yet.
    Mar 2014
    Mount Pleasant, NC
    Total Hrs: 156
    Sorry it's been a while since I posted but we have been waiting for stuff, once we got the wiring from Wayne we got motivated to work on her again. Here is the latest work:
    We are hoping to get her running soon and then test drive it at Roebling Road next month or Carolina (CMP) in May...
    Apr 2014
    Shelton, CT
    wow that is fast progress!
    Tamra
    Mar 2014
    Mount Pleasant, NC
    Total Hrs: 164
    Got most of the wiring installed, got axles from the Driveshaft shop in Salisbury but they screwed them up and the axles have to go back. They simply made a set of front axles! Lots of hoodpins installed and the new tank is plumbed. Wrapping up wiring and interior next...
    Mar 2014
    Mount Pleasant, NC
    It's been a while since I posted but we have been busy working on the wiring harness to fix problems.
    Road Atlanta this weekend was a success and a learning experience. It all started Friday morning. Lots of work needed to be done to get the car on the track. First was the oil leak, next was burping the cooling system, seat belts, firewall, and lastly the front suspension setup (which took from 3pm to about 7-8pm to finish). Once all that was done it was time to drive the car around the paddock to test it. Driving it showed that the cooling system would overheat very quickly. We tried burping the system a couple more times and thought that it might be a head gasket failure. Didn't get time to get a radiator pressure tester on it until lunch on Saturday. Checked the whole system and found it was not a head gasket, but more air bubbles in the system. Bleed the system again and drove it around the paddock and found that it would lower the temperature when the car was moving now. Decided to take it out on track for the last session of the day on Saturday. Drove out there found that the tires hit the fenders on track even after we raised the front coil overs 8 turns. Drove around at a normal pace and temperature seemed to be working well.
    When we tried to start it in the morning, it would not start. We went to tuning and it could not fix it. We will bring it home and see what could be wrong. Pretty successful weekend, but more work needs to happen before the next event. We will start by taking the wiring harness apart as it seems to have lots of noise in it, not sure why but going to do our best to determine what the problem with the wiring is. I'll keep you posted!
    Oh and here's a short clip of brake hose failure going into T10a at Road Atlanta:
    https://www.youtube.com/watch?v=hjCWltgA29k
    Administrator
    Enterprise Alabama
    Did you do my cooling system mod?
    Mar 2014
    Mount Pleasant, NC
    We eventually got the air bubbles out and it ran fine, where can I find out more about your cooling system mod?
    Clovis, Ca
    Did you guys fix your problems? Has it been on the track again?
    Thanks- Chad
