Thanks Thanks:  13
Likes Likes:  25
Page 11 of 21 FirstFirst ... 910111213 ... LastLast
Results 401 to 440 of 804
Thread: Oil issues: Dry Sump, Accusump for road racing?
  1. #401
    Sgt.Gator's Avatar
    Bend, Oregon
    Bob can you find a way to datalog oil pressures? A gauge won't be nearly as good. Temp yes because it doesn't swing like crazy, but pressures fly around fast.
    Owner: Colonel Red Racing
    818R ICSCC SPM
  2. #402
    Yes, I going to bring temp and pressure into my TGV sensor inputs. Hopefully I can get it working by this weekend. The replacement motor is still sitting on the floor. I decided to take Thursday and Friday off work to make sure we make it to the track.
  3. #403
    Leesburg, VA
    Bob, what's your approach to logging oil temp? I rigged up the oil pressure sensor you posted a while back but am still trying to figure out what to do about the oil temp. I have the prosport gauge and sensor, which as far as I can tell is a 2.5kOhm thermistor. I'm thinking of connecting this thermistor directly to the gas tank temp sensor wire and recalibrating the temp curve in rom raider logger. Is your plan to do thermocouple to 0-5V conversion board?
  4. #404
    I'll let you know tomorrow. I'm going to try a thermistor type sensor with a voltage divider resistor. connect it to the TGV sensor plug. The trick will be playing with the table to make it read out in degrees F.
  5. #405
    Leesburg, VA
    Bob, can you check my math?
    Vo = (R*Vcc)/(R+R_ref)
    where: Vo is the output voltage, Vcc is 5V, R is the thermistor value, and R_ref is the fixed resistor value for tuning the curve. For a 2.5kOhm thermistor and a 1kOhm fixed resistor, I'm getting this type of response curve:
    For R_ref = 400 ohms, I get:
  6. #406
    We are using an IQ3, oil pressure is 90psi when warm, waiting for oil temp to log but with the 20 row cooler, pretty sure we will be ok. Love a digital dash........
  7. #407
    Your graphs looks correct.
    Is there a table in the ECU for the TGV so the SSM will spit out temperature in degrees C or F?
  8. #408
    Leesburg, VA
    I've looked at the definitions file for rom raider logger and the ecu raw value for TGV data is V*50. So the logger must divide this raw value by 50 to show the true TGV voltage. I don't know if this expression can be changed directly in the ecu but it can be changed in the logger by modifying the definitions file (.xml). You'd need to know the function of temperature vs voltage for whatever sensor you're using.
    For instance, the raw value expression for the fuel temp sensor is:
    For degrees F ==> "32+9*(x-40)/5"
    For degrees C ==> "x-40"
    where x is the ecu raw value.
    One thing I'm going to try is connecting the thermistor that came with my prosport oil temp gauge to the gas temp signal wire and record the raw ecu value when dipping that thermistor in a cup of water at different temperatures. This should give me a calibration curve that I can update in the logger definition file. I'm not sure how linear that curve will be as thermistors tend to follow:
    1/T = 1/To + (1/B)*ln(R/Ro)
  9. #409
    Sgt.Gator's Avatar
    Bend, Oregon
    Is anyone here aware of an 818 with a mandrel pulley coming off the crank pulley and fitting in an 818? I'm sure it's a very close fitment, trying to figure out if it will clear the frame and firewall.
    A couple of shots of a DS pump using the mandrel:
    The more I look at them the more I think they won't fit!
    818R ICSCC SPM
  10. #410
    Senior Member Mulry's Avatar
    Dallas
    This is what we are going to do. We have test fitted the engine in the chassis and it appears that the crank mandrel will miss the structure of the frame/firewall. We are working on custom fabrication of the DS pump mount so that we know our center-center distance before ordering the mandrel for the crank and the pulleys for the pump and the crank mandrel.
    The real trick in your first photo is that the line routing out of the bottom of the DS pump would wrap around the outside of the exhaust headers, which might do very bad things to those oil lines. We've mocked up the routing around the rear of the engine to avoid that situation, but no final conclusions yet.
  11. #411
    Sgt.Gator's Avatar
    Bend, Oregon
    Quote Originally Posted by Mulry View Post
    Thanks, I'm looking forward to seeing your fitment pic.
    I routed the lines as you see in the pic on my LGT, it was no problem. Obviously not as tight as the pic, and I put firesleeve on them. It's pretty easy to find a way to pull them a few inches away from the headers. To go straight back over the back might be possible in a 818, much harder in a LGT or STI.
    818R ICSCC SPM
  12. #412
    Gentlemen, the jury is in, you must have a dry sump if you are pulling these kind of g's.
  13. #413
    south-central CT
    And what would that G limit be? What have the R's been capable of? A deep KB pan and Accusump setup has failed (when there were no oil heat issues)? I know a lot of questions but I've been out of touch and can't keep up with failures and DS/non-DS successes.
  14. #414
    Dallas
    It wouldn't surprise me if Retro had some logged data to answer this precisely (and Plavan probably does too), but I suspect that you would hit this limit even on 200 treadwear tires. It seems like there are a lot more DS failures than non-DS successes. There's a reason that every competition boxer engine gets dry sumped, and it's not because teams like spending extra money and complexity on dry sump systems.
  15. #415
    Clovis, Ca
    IIRC I was pulling 1.5G+
    I would not even track a 818S on street tires without a drysump.
    Dry Sump failures on 818R's- There only one I can think of (Brando). However, he did not have any oil temp, oil pressure, or any other gauges. He also did not have an external oil cooler.
    I remember he blew up a motor without the drysump after 1.5 track days, then had the motor rebuilt and the engine builder REUSED the factory oil/water heat exchanger with all those metal bits inside. Then quickly blew up that motor.....and the tune was suspect and possible turbo hose failure (Boost controller)
    Save your money and ADD a drysump..... It's not going to hurt as much as blowing motors. If you think a deep pan, an AOS or Killer B valve is going to save you, Just start throwing money away or paypal me. I'll put the money to better use!
    My car has over 20 track days now including the new owner. Still working great (knock on wood). Also, do not use the 11mm oil pump- the 10mm oil pump fixed my oil heating issues. It bypassed the whole time just circulating the oil inside the motor. See oil pump flow chart...
    Thanks- Chad
  16. #416
    Sgt.Gator's Avatar
    Bend, Oregon
    Chad I think the only note to make about the oil pumps is to use the 10mm for a stock-oem block, especially on a SAVCS oem motor. A forged built block may need an 11 or 12 mm. On my new forged block from Rallispec they said the min pump is the 11 mm and the 12mm is preferred. I went full monty with the Cosworth 12mm pump. So if your builder specs an 11 or 12 I think you should follow their guidance.
    818R ICSCC SPM
  17. #417
    Clovis, Ca
    Mine was a non-OEM built motor. SAVCS yes
    Thanks- Chad
  18. #418
    We were running slicks, 235 front, 265 rear. Our logger was not working, but we know what the issue was. Blow by was stupid, even with the Grimmspeed AOS, killer b pan and pickup, we went down a quart and Pooched the engine after maybe 40min of track time.
    Oil temps are not an issue with the 11mm pump from Rally sport, 95psi pretty much all of the time as far as I could see, with oil temps under 190 with the external cooler. Its all about the oil control, which the dry sump seems to take care of.
  19. #419
    Mar 2014
    Oakley, CA
    So, for those of us who are a little slower to the barn - why did you have so much blow-by and how did that cause the engine to fail?
  20. #420
    It blew out a quart of oil, which I guess is enough to starve the pickup in even a Killer Bee pan.
  21. #421
    south-central CT
    Blowby is usually a ring issue. Extreme boost will cause more blowby and the oil sloshing and crank/rod whipping possible when racing exacerbates the oil mist. Hoses too small going to the AOS will increase air velocity and move more oil mist out of the crankcase.
    I have never been a fan of capturing and holding the oil; especially in a track car. I feel it should be allowed to return to the crankcase. This, after I blew a stockish, 2008 STi motor. I was at the track and the AOS filled and overflowed back into the intake, causing detonation and broken pistons. After replumbing, I've run the same 500 HP motor for three years on the track with the AOS dumping oil back into the engine through the PCV hole. Granted, my STi cannot generate the G's a well-prepared 818R can but it was doing competitive ST2 laps.
  22. #422
    south-central CT
    Per my comment, where did the quart of oil go? Did it overflow the tank and where does the vent go? I cannot imaging a quart causing starvation but perhaps on a long sweeping turn it could (without an Accusump). I believe it is common practice to slightly overfill when racing a Subie.
  23. #423
    We did overfill a bit, we were running the Grimmspeed oil cap style AOS that dumps it back into the pan, but the amount of oil going into the intake was too much, so we changed it to a dump can, for one session. We are running 1lb Under stock boost.
  24. #424
    Suisun City, CA
    I've never heard of anyone with success using the Grimmspeed AOS on the track.
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
  25. #425
    Sgt.Gator's Avatar
    Bend, Oregon
    Quote Originally Posted by JeromeS13 View Post
    +1 on that.
    818R ICSCC SPM
  26. #426
    Feb 2014
    Oil level in the pan drops when the engine is running. Compound that with corner loads and the outside facing head starts to hold oil as well. This can very simply be simulated on an engine stand by tipping the engine. You can see oil begin to pool into the lower (outside facing) head, and the sump level drop. Remove an additional quart and that level gets dangerously low. At those forces the balance and vent lines are also going to be holding oil as well, further reducing the level in the sump.
    The OEM STi get flakey ~1.2Gs and the older flat bottom pans are even worse. The 818 easily produces forces well above that.
    I'd still like to see datalogs regarding our setup (pan/pickup/baffle and oil control valve) with a properly setup A/O separator showing starvation.
    Agree with Scargo, A/O separator is the way to go on these engines vs storing oil in a can.
  27. #427
    +1 on that.
    +2, bad things happened.
  28. #428
    Bowling Green, KY
    Had a DS ordered a while back, made a U turn and continued to research running a wet sump. I guess I have just dug my heals in and am determined to run my wet sump successfully. Read all I can find and talked to all that would e-mail or pick up the phone from North America, Europe and Japan. I am logging, pressures, temps and g loads so I will find out soon.
    I will take all the I told you so's if I am not successful but I am going forward with confidence.
  29. #429
    south-central CT
    I feel the key to my 490 CHP/395 WHP engine longevity, in my ST2 level STi... is all the Killer B parts, the Accusump, the large oil cooler, large, external oil filter and simple A/OS that drains back. Almost nine quarts of oil. According to others, the two quart Accusump can do a few seconds of supplemental oil supply. It seems like mine takes a bit longer to bleed down. It should come into play as a transition to it as the pressure drops rather than a sudden dump. I have not been on a track that exceeds 11 seconds of sustained G's. It survived that track (NJMP Lightning) many times. Lightning is not very banked, but it has also survived multiple days at NHMP, Watkins Glen, Palmer and Thompson (all in the N-E). I don't have data-logging but I'm sure other ST2 cars have data that can be found. John George comes to mind.
    Please don't get the idea that I am saying positively that you can get by without a DS on a high G 818R. DS's the route I plan to take.
    Last edited by Scargo; 08-31-2016 at 05:27 AM. Reason: Changed comment about Accusump performance
  30. #430
    Kirkland, WA
    Granted my car was not running to it's fullest but I did feel the potential of the car in the corners. I currently have a wet sump much like Mitch (with Killer-B and Cosworth components). I have ordered a Elements Tuning DS after feeling the car and also what happened to retroracing. I really did not want to have to do this and mainly doing this as insurance. My plan is to keep the oil cooler setup, run the stock oil pump and pulley system and just add the DS. I have a AOS and Killer-B Oil Control Valve and not sure what I will do there. The center drive 818 is running the element tuning DS but also is running a AOS due to oil in the throttle body.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  31. #431
    I'm not saying that you could make it work with the full KB setup and accusump for an hour, or maybe even two, but I have doubts about 25 hours of 2g corners. Our system was supposed to empty into the oil fill, but the shear volume of oil was to much for it to handle.
    Our second engine is back into the car awaiting the dry sump for the end of this week. We had to also do some serious thermal control under the hood, we melted the timing belt cover even though we have the full exhaust wrapped.....
  32. #432
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    The Lotus Elise/Exige has NACA ducts in the belly pan to bring cooler air into the engine compartment
  33. #433
    We thought about that, but you lose downforce as a result. We are venting the top for now
  34. #434
    Sgt.Gator's Avatar
    Bend, Oregon
    Holy Heat Soak Retro!
    At least at Thunderhill it should be less than 103 degrees in December....if not snowing.
    818R ICSCC SPM
  35. #435
    Mar 2014
    Oakley, CA
    Good heavens..... How the hell do the Porsche turbo motors not melt everything?
  36. #436
    Sgt.Gator's Avatar
    Bend, Oregon
    This makes no sense to me. Every DS system I've seen in a race car eliminates any possibility of oil in the intake because the PCV, hoses, breathers, all that stuff, are gone. In a street car like a Corvette Z06 that comes with a factory dry sump oil in the intake occurs because all that stuff is still hooked up. But in a race car it should be gone.
    For my new STI engine I'm considering making a custom hard pipe intake simply because there is no reason to have all the vacuum spigots on a stock or aftermarket intake pipe. Since I'll be running a VTA BPV there is no need for any openings in the intake pipe at all. That eliminates several potential points of failure if there are no caps, plugs, or hoses that can pop off.
    I hope to see the centerdrive 818 soon at an event so I can understand why they still have an AOS and oil in the intake tract.
    818R ICSCC SPM
  37. #437
    south-central CT
    What Sgt Gator said... I tried to post this earlier from my phone. In a racing application, why would you ever want to pull a vacuum on an A/OS from the intake manifold, when you can vent to atmosphere? Perhaps you could avoid breakage with forged pistons and low boost but performance would suffer if significant oil gets pulled in.
  38. #438
    Leesburg, VA
    Doesn't the boost control solenoid need a vacuum reference pre turbo?
  39. #439
    The issue, as explained to me by Elements, is that some guys don't just vent the valve covers to the DS tank. Pulling vacuum top and bottom of engine negates the benefit of both. Shouldn't the EGR be closed off and the valve covers be just vented directly to the DS tank to retain vacuum in the block?
  40. #440
    Kirkland, WA
    My understanding is that the remote oil cooler and filter can be left as it is, the AOS and Killer-B Oil Control Valve can be left as it as these attach to the valve cover vents and the Dry Sump is a stand alone system, so basically you have 3 stand alone systems (1) Oil Cooler/remote Oil Filter (2) Valve cover venting system (AOS and Oil Control Valve) aand (3) Dry sump, pan, pump and tank
    Tony Nadalin
