I better go back and explain the components better. I have a Summit after market EFI harness that has gotten really good ratings (SUM-890120). I also have the AAW body harness so all wiring is new except the trans harness which is OEM but in excellent condition-retaped and continuity on all circuits). I also did a lot of research on the instruction data and liked many of the features including an inertia switch connection. The MAF I got to match to the 24 lb injectors also Summit is this: SUM-29051B-C. The C is for cold air system. The cold air was planned from the beginning to get cooler passenger side fender air instead of engine bay air.
So it is the cold air version. I'm using a Summit 75 mm throttle body which is port matched to the Holley Systemax folded plenum chamber intake. I have stock fuel rails, regulator, coil, sensors, fuel pump, tank, T-5 trans, EEC-IV PCM all coming from a 92GT. Recently, I found that I had installed the black TFI module instead of the correct gray one but now that has been fixed. My basic timing (without Spout) is 12.5 to 13 degrees which I was finally able to verify (had difficulty reading the timing marks on the balancer but finally got the right combo of paint for color contrast).
I planned to check fuel rail pressure under load but have not been able to get gauge to work this time. I think someone abused it the last time it was used. Taking it back for replacement. Will start again tomorrow. I've been double checking for vacuum leaks, distributor wire arrangement making sure wires are spaced and not touching, firing order, etc. Will probably have some representative numbers by Monday evening. Thanks,
WEK.
