Very disappointed in FFR's woefully inadequate assembly manual directions for adapting the WRX wiring harness to the 818S: Their schematic shows the "main fuse panel" above the fuel tank on driver's side and the other fuse panel under the dash. Well, after mounting the one panel above the fuel tank (sensible because it gives good access to the engine harness and starter), the other fuse panel (the one originally under the dash) ends up in the middle of the center tunnel. I have had to add 36 inches of wire to each of approx. 40 wires in order to be able to mount the panel under the dash. Did I make the wrong choice or was FFR remiss in their directions?
