Thread: Speedo Wiring
    Speedo Wiring
    Got all the gauges hooked up, everything works except speedo. I am using the RF harness with the stock tranny sender on a TKO 500 & FFR Electronic Vintage gauges. Plug on RF harness fits into trans sender. Two wires at Dash for speedo signal are green & grey, speedo has black and white wires. Any Ideas on how to hook this up would be appreciated.
    Just out of paint shop.
    Coupe#624
    Bill
    Gorham, ME
    The sppedometer needs to be calibrated first before it will work. Very easy to do if directions are followed. That being said it took me four tries before I got it calibrated because I didn't follow the instructions correctly. 74 year old brain failures here at fault.
    Bill
    Coupe #421, Picked Up 11/15/08, started 1/1/09 - Rebuilt mildly massaged 302, T5, 3 Link, and Loads of Extras
    Henley MO
    OK I have the autometer speedo. From the two wire sender at the trans one wire to ground the other to the SIG terminal on the speedometer. ( without computer )
    Chaz...
    Quote Originally Posted by CHAZC5ZX View Post
    Chaz...
    Got it all worked out, THANKS GUYS!
