Results 1 to 9 of 9
Thread: 33 hot rod fuel tank plate
    Jun 2014
    I just received my fuel tank plate from FFR. It also came with two other small plates. I was told that I need them too. I don't know where they go. Has anyone installed these plates. If so can you post a picture. The part numbers for these plates are 33958 and 3359. I am attaching a picture of the plates.
    Thanks for any help provided
    larry don,t have car or photo but have latested pdf manual shows to be left & right closeout panels at gas tank on page 381 kick up is at the bottom at the door post runs up tube out side of roll bar tube says to put push on weather seal on push against body seal and rivet hope that helps
    Jun 2014
    Found it in the book. Thank you for your help.
    Larry
    Fresno, CA
    I have never seen those two panels before. My 33 is very early and did not have this item.
    Doug
    Dec 2013
    Cologn MN
    Quote Originally Posted by Larry View Post
    My book (October 2013) doesn’t show these on the referenced page. What version manual do you have?
    33 Hot Rod #664 BrentM's Avatar
    May 2013
    These are new panels, I found them in the 1Z manual
    I didn't get them with my kit.
    Dec 2013
    Cologn MN
    Quote Originally Posted by BrentM View Post
    I went through my parts last night and found that I didn't either. I'm wondering if the factory will send them or if this is an upgrade that we would have to purchase?
    Mar 2014
    Larry,
    My kit (#698) had the sheet of aluminum under the fuel tank location, however, I do not remember seeing side oanels and will keep looking. I did look at my dis-assembly pictures and do not see the panels.
    Out of curiosity, what is your kit #?
    Scot
    [QUOTE=Larry;170000]I just received my fuel tank plate from FFR. It also came with two other small plates. I was told that I need them too. I don't know where they go. Has anyone installed these plates. If so can you post a picture. The part numbers for these plates are 33958 and 3359. I am attaching a picture of the plates.
    Larry
    I've been selling the fuel tank sill plates for three years. Flattered that the factory thought it was a good idea but the addition of the second component makes little sense to me. My wheel well panel and the new door hings seals do an effective job of sealing.
