0
0
Throttle Cable Routing
This seems like it should be an easy one, but I can't find it in the manual or on the forum . . .
What is the best way to route the throttle cable? (I'm using an '02 donor, of that matters.) Does it go through the tunnel? If so, I assume it passes through the large grommet in the firewall - is that right?
Buzz
I ran mine through the small grommet on the left and through the tunnel, might be wrong but it looks ok
I went through the large grommet hole since the 2 smaller are being used by my shifter cables. It's a little short IMO but it works. I secured it with p-clamps inside the tunnel. You can see it on my build thread.
I have k-tune shifter so I have empty holes to use
