I was wondering what are the exact parts you will need from the donor car's door assembly. Do you just need the internal handle or the entire mechanism?
Definitely the interior handle, the latch mechanism, and the striker plate. Not sure about the rods in between.
you need the actuation rod and the lock rod if you want to use the lock mechanism
I guess...
I haven't got there yet, but thanks for the heads up to fix the latch in the unlocked position! Although it may be easy to attach the lock, since my (and many) 818s will likely not get a hard-top, a lock seems about as useful as a screen door on a submarine. . As for it flopping around... I plan to ditch the handle and use a pull-strap.
