So, I think I've found the source of my oil leak: my pancake style thermostat inlet and outlet are -10 AN O-ring fittings. I have just regular -10 AN fittings on there. Can I just add an o-ring to the fitting I have or is it a special fitting?
Build Blog
#8203, carbed 427W (611 hp), TKO 600, IRS
Delivered: May 27, 2014
Mechanically "Complete": October 1, 2014
Never mind. I bit the bullet and bought new fittings. With expedited shipping, of course...
Build Blog
Give us an update when it's fixed. I am no expert by any means but have not heard of an 'o-ring An fitting'.
O-ring AN have a straight cut thread instead of NPT on one end and use an O-ring to make the seal when tightened. It has a regular AN fitting on the other end.
Chuck Krueger
2000 C5
2003 C5 Z06
2007 C5 Z06
Its an orb fitting, (o-ring base)
Build Blog
Ok, got it. I wasn't thinking of the other end of the fitting.
I replaced the regular -AN flared fitting with an o-ring fitting and that has solved the leak.
Build Blog
