Results 1 to 5 of 5
Thread: passenger foot box
    minnetonka,MN
    passenger foot box
    can anyone tell me how many inches it is from the bottom of the dash to the floor of passenger side foot box
    MkIII: 16 7/8 inch from dash to carpet surface. There is a 2 inch drop in the front footbox floor. I have about 3/8 inch extra insulation between the FFR carpet and the "Hushmat" (Dynamat like). WEK.
    minnetonka,MN
    thanks skull
    2bking's Avatar
    Garland, Texas
    My MK4 measures 15 before the drop and 17 after. This is between the bottom of the 2" square tube at the firewall and the top of the 2" square tube where the floor under the seat attaches/sits on. The foot box floor attaches to the bottom of the same tube making the 2" drop into the foot box. AC ducts and other parts may protrude below the lower surface of the upper 2" tube. The transition between the floors can be seen in this picture.
    King
    minnetonka,MN
    thanks 2b
