Results 1 to 33 of 33
Thread: Who sells cool side mirrors that will fit on the door of my 818s?
    anderson
    Talking Who sells cool side mirrors that will fit on the door of my 818s?
    Any ideas where i can get black or carbon fiber looking mirrors that will attach to the lh and rh doors? I dont want to use the plates ffr suggested but mount the mirrors on the skin
    for a better look
    thanks in advance for any ideas!
    Kerry
    wallace18's Avatar
    Trenton, Florida
    Speedway sells black Hollywood mirrors that I used on my build and others have used them as well.
    I'm probably going to go with these: http://www.hrpworld.com/store/defaul...or-lenses.html
    Freeport, ME
    I'm using those, they are very pretty!
    Dan
    Mechie3's Avatar
    Indianapolis
    For a cheaper route, new style challenger (yes, dodge) look to have the right angle and style to work.
    Zero Decibel Motorsports
    Check out my new website!
    Senior Member fact5racer's Avatar
    Jul 2012
    Encinitas, CA
    I just received my mirrors today. They're similar to the carbon fiber APR GT3 mirrrors, but cheaper... and I think the shape of these will works better on the 818. $130 shipped (came direct from Taiwan quick) with hardware, and the quality looks good.
    http://www.ebay.com/itm/281411253111
    So who wants my donor mirrors? (They're white and polished up nice and I already powder coated the mounts black!)
    Senior Member metros's Avatar
    NoVA
    I like those. Looking forward to seeing them mounted.
    These style mirrors make a big difference on the 818 IMO.
    San Diego Ca 92106
    Bumping this old thread. Has anyone used the mirrors F5 sells in their catalog?
    http://www.factoryfiveparts.com/818-...ew-mirror-set/
    Have you looked as possibly using "Sport Bike" mirrors?
    Many bikes have some great looking mirrors and they scale nicely on small cars.
    Places like J&P Cycles, Dennis Kirk and The Motorcycle Super Store all have nice selections of after market pieces as well.
    San Diego Ca 92106
    Keeping my options open, looking for affordable good looking mirrors that mount solidly so they don't shake when going down the road.
    Feb 2014
    Asheville, NC
    I use these myself and can see out of them on the track just fine (so at triple digit speeds). I really like them; they're light, they look cool, and they weren't terribly expensive.
    I ordered them through Pegasus racing; brand is Race Mirrors (go figure).
    My build thread has more pics of them.
    Frank - Build thread
    Kirkland, WA
    I'm looking for ones that use a tube mount so I can mount to my side roll cage bars so they will be stable.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Member CNC_Geek's Avatar
    Feb 2013
    Southern California
    Mirrors are one item where I was especially picky. My car will be for street and I want it to look special. After scanning every car on the road there was only one production car with stylish (sporty looking) side view mirrors. 2010 to 2015 Camaro. These are available from aftermarket but I held out for genuine GM production mirrors. There are 3 drawbacks to using these. 1, these mirrors would look more appropriate if they were scaled down in size about 15%. 2. They require much hand crafting to mount. I have to cut into the door skin. Then, build a solid mount attaching to the metal door frame. 3, part of the exposed lower mounting will require filling and shaping to blend properly with the door. It has turned out to be a bigger project than I had wanted but I do love an engineering challenge. The fact that mounting these is difficult makes it even more special.
    Harley818's Avatar
    Vancouver BC
    Quote Originally Posted by wleehendrick View Post
    Wleehendrick - how are these mirrors holding up? Do you have them installed, and are they rigid enough. I like the looks, but I don't want want them bouncing around....
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    Feb 2014
    Wellington, New Zealand
    Got mine from a wrecker and covered them in carbon fibre wrap. They are off a Jaguar XJ6 and are electric so able to be adjusted from the drivers seat. Cost all of $30.
    Cheers
    George
    Jul 2012
    Encinitas, CA
    Hi Harley,
    I wish I could tell you! My build has slowed to a crawl since buying a house last year and working on that.
    However, just from inspection, they look solid. They are not quickly adjustable; since you have to loosen and tighten bolts to adjust, I expect/hope they'll be pretty stable. They're light, so if anything I would think wind buffeting would be more of an issue with regards to stability than vibration/bouncing.
    Also, both mirrors are convex, so they provide a wide field of view (but de-magnify the image; i.e "objects are closer than they appear").
    Lee
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I have the same as wleehendrick, or very very close. Plenty sturdy but as mentioned, you have to tighten and loosen bolts to adjust them and the biggest problem with that is that the main tensioning bolt for the arm is underneath the mounting point. Once you tighten it, the mirror won't adjust on that pivot point. Taking the mirror out means taking the door panel off.
    Banned
    I just put these on my car this weekend. Haven't had a chance to drive at speed with them yet but my only doubt would be the relatively small contact area inside the door panel (they're held on with two #8 screws w/washers.) Due to the curvature of the door it's going to be touch to increase that much but it's probably the same issue you'll have with any other mirror that mounts similarly. For $45 I don't think they could be beat. (Someone bought one donor mirror for $40 so these were pretty much paid for and look way better.
    Dec 2014
    north east ct
    Edmonton, Alberta
    Wow, those Honda mirrors look great!
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Apr 2015
    Andover, MA
    Quote Originally Posted by brian b 36 View Post
    Brian, I bought del sol mirrors after seeing them in your build thread I think. Do you have some shots that show how you installed?
    -Ben
    Dec 2014
    north east ct
    I do not but the next time i pull the door panels off i will take some pics they are solid and do not move at all like the rear view mirror even at 125 at thompson speedway
    Mechie3's Avatar
    Indianapolis
    With those 5 spokes it reminds me of a carrera GT.
    Harley818's Avatar
    Vancouver BC
    Brian - these Honda mirrors look great!
    I saw some Subaru BRZ mirrors and thought they would look good - they are very similar.
    Harley
    Sep 2014
    Looking for a match to the original 85/86 Ferrari Testarossa mirrors that are mounted on the door frame/ midway up the windshield. Loved the look when I fist saw them, and think they would be awesome on the 818C.
    This is an 85/86 - in 87 they went to the corner of the door/window.
    Any ideas ?
    "E"
    Apr 2015
    Andover, MA
    I've always like that style on the Testarossa as well....the 818 windshield frame is pretty thin though!
    Quote Originally Posted by Innkeepr View Post
    Any ideas ?
    "E"
    Feb 2013
    Southern California
    Finally have my doors mounted and working. I have installed the side view mirrors from a late model Camaro. IMG_0513.JPGIMG_0516.JPG818_0495_PS.jpg
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Those look great
    Feb 2013
    Southern California
    Some things I let slide but the mirrors are a focal point. It was a lot of work getting these mounted but I really like the sporty styling.
    I like the spacer at the fender/side sale connection.
    I have a saying, " If you can't fix it, Feature it."
    PS, I like the mirrors.
    San Diego Ca 92106
    Those Camaro mirrors are a nice fit with the 818 body lines. I'll have to make a mental note. . I wonder how they would look if they weren't mounted to the doors but rather make a bracket and fit it in the gap were the windshield,fender and door meet?
    Feb 2013
    Southern California
    I had to space the fenders higher to blend the parts and lines. Here is my solution. Lemon-IMG_0530.JPGaid out of lemons.
