0
0
Fuel System Diagnostic Trouble Codes (DTCs)
I am using the Boyd fuel tank in my 818S. There is no fuel temperature sensor and I am using none of the evaporative emission control stuff. Therefore, I think the following DTCs can be disabled in the ECU. I will appreciate any comments / advice from any of you car guys that know more about this stuff than I.
Also, are any of these signals used for control in the ECU such that I need to enter a "dummy" value in a table or something?
P0181 Fuel Temperature Sensor “A” Circuit Range/Performance
P0182 Fuel Temperature Sensor “A” Circuit Low Input
P0183 Fuel Temperature Sensor “A” Circuit High Input
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0456 Evaporative Emission Control System Leak Detected (very small leak)
P0457 Evaporative Emission Control System Leak Detected (fuel cap loose/ off)
P0458 Evaporative Emission Control System Purge Control Valve Circuit Low
P0459 Evaporative Emission Control System Purge Control Valve Circuit High
P1400 Fuel Tank Pressure Control Solenoid Valve Circuit Low
P1420 Fuel Tank Pressure Control Sol. Valve Circuit High
P1443 Vent Control Solenoid Valve Function Problem
get a Tactrix cable and ECUFlash software. The software is free. The cable is under $200.00. You could also borrow one, it doesn't get married to the ECU like the Cobb stuff. I never used one before and it only took me 10 minutes to take care of exactly what you are talking about.
Pretty much all Evap codes can simply be "turned off" or disabled. There shouldn't be any that need values.
I kept 458 and 459 because I kept the purge valve, but otherwise that looks like the same list I did.
Larry
I couldn't get rid of P0183. I posted it over at NASIOC and the word was that the fuel temp sensor might be used in the ECU logic somewhere. I ended up duct taping the fuel temp sensor to the outside of the tank and hooking it up.
- You may not post replies
- You may not edit your posts
Forum Rules
