I install the mid shifter on my TKO 600 and it has adjustable stops for the shifter with instructions for adjustment. It is an after market shifter. When I purchased it, the Tremec shifter wasn't available because it had been discontinued.
The instruction sheet that came with the transmission says to remove the stops on after market shifters because it can't be over shifted. Here is the paragraph:
So my question is: What are the experiences with the mid shifter. Are you removing the stops?
