Front light bulbs
My donor WRX suffered a frontal crash. As a result the front lights and bulbs were all mangled or missing. The FFR manual says the "high beam connector, bulb, and directional bulb are all Subaru". Anyone know what part numbers I need to source? I think the high beam bulbs are 9007. I have since determined that the 9007 bulb that fits the Subaru is wrong for the 818. Although it correctly mates with the connector, the plastic bayonet mount of the bulb is way bigger than the hole in the FFR supplied front light fixture. Also, FFR does actually supply the bulbs needed for the front directional. Should I be looking for a bulb to fit a Camry fixture?
