Newbie from outside Philly. Picked up my Roadster kit about 5 weeks ago and trying to dig in, hoping to start a build thread in a few weeks.
Have my front suspension on, working on the brakes. I have an issue with rear brakes I can't quite figure out, hoping someone has seen something similar.
Have the Wilwood brake option, rear driver side brakes seemed to go on pretty easily. Passenger side has me puzzled. C-Bracket went on the axle fine. Caliper bracket is on but for some reason when I put on the rotor, the bracket does not line up exactly with the rotor. Considering putting more shims on one bolt than the other but Wilwood instructions advise against. Also when I slide the caliper on, the outside pad rubs on the rotor. First thought is to remove shims to shift the caliper out from the rotor but the shims move the entire bracket/caliper assembly and caliper bracket gets to a point where it starts contacting the inside face of the rotor. What am I missing? I'm thinking it might be an issue with the axle but need to pick it apart some more. Any insight would be greatly appreciated.
Included an image of where the caliper bracket and rotor meet.
