I went to put the body on the chassis today with the help of 2 friends. I have done everything in the manual up to the body part. In the back the rear hits the fuel tank and will not allow the back to go all the way on. On the rear trunk aluminum I put some weather strip on the top. Was this a mistake? Should I cut the rectangle area on the bottom around the tank so it fits? I do not see how to do it otherwise. also the flaps from the side rear aluminum do I tuck them in or worry about them after the body is on? Any hints from anyone who has done this would be so much appreciated. Thanks. TW.
