Looking for a 2002 fan assembly with 4 wire black connector or a female 4 wire black connector, willing to trade also as I have 2006 fan assembly with 3 wire white connector
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
I was just getting to emails this morning. It's actually the 02/03 is the 3 pin and the 04+ WRX and STi is 4 pin.
When we say to our customers "if there is anything you need, please ask," we mean it.
iWire Subaru Wiring Services
Over 100 Custom 818 Wiring Harnesses Built
http://www.iwireservices.com/factory...18-wiring-kits
[email protected]
My mistake, you are right my harness was an 02 WRX which had the 3 pin and some how I got a 04' fan with a 4 wire so somehow.
Tony Nadalin
[email protected]
What's the best way to wire aftermarket fans? I've got an 02 harness with two fan plugs (3 wires each). Is it ok to splice the two power wires together on each fan connector to work with the 2 wire fans?
My fans only have 2 leads so I connected the grounds (obviously) and both the speed circuits into the fan hot lead. Worked perfectly -and I confirm the fans did run when the trigger was sent by the ECU during the dyno test.
Awesome, thanks Mike, that's what I needed to know.
