Thread: ODB-II to CAN
    Kirkland, WA
    ODB-II to CAN
    Anyone aware of a adapter to go from OBD-II to CAN ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Hi Tony
    I can (pun) make one out of an arduino. Problem you are going to have with any adaptor is being limited to the OBDii speed. If you want just a few parameters out of the OBDii it won't be to bad. But if your looking for a bunch of data you might get into the 1 second or more update times.
    Kirkland, WA
    Bob, I understand the speed mismatch but this would be going from ODB-II to a CAN bus, so slower to faster should not matter, right ?
    Tony Nadalin
    You are correct, the data would come out of CAN at ODDii intervals.
    For instance, If 10 message came out of OBDii per second. The same 10 messages would come out of CAN per second.
    Research Calibrator sponaugle's Avatar
    Portland, OR
    Are you looking to get data from a Subaru factory ECU transmitted over CAN? If so, you would want to use SSM, not the regular OBD-II protocol. It is still a relatively slow protocol at 4800 baud, and with 10-15 things monitored you are looking at 8-10 samples per second. I am working on a PCB right now that can collect data from SSM and a few other protocols and send them over CAN (so they can be logged in my RaceCapture Pro) if you are interested.
    Quote Originally Posted by sponaugle View Post
    I am very interested if you can get the data using SSM.
    I use a parker plc on my electric vehicles. It has 3 can ports. I can do gauges, bar graphs and much more on the screen. Plus I can add plenty of I/o for additional sensors. Here is a couple of screen shot samples.
