Results 1 to 6 of 6
Thread: Help, which side do i place alternator
    Dec 2013
    Question Help, which side do i place alternator
    Hi, I am new to this forum. Started building #631 in February 2014. Have run into glitch. I installed a 347 stroker from Blueprint engines and ready to buy alternator but having problemes deciding which side is best. Was thinking of installing on passenger side using a March alternator bracket kit (#30395) from summit but seems a bit low and afraid alternator will not fit between frame and motor.
    Has anyone installed a 347 stroker in the 33 rod. If so please help.
    TURP
    Mine was located high on drivers side. See my 33 build thread.
    Norton, MA USA earth
    I make a bracket that mounts it high or low on the passenger side.
    check it out at www.replicaparts.com
    Dec 2013
    Thanks, will check your build thread
    Dec 2013
    Thanks, will check web site
    Fresno, CA
    Mine is mounted high on the drivers side.
    Doug
