Likes Likes:  3
Page 3 of 37 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 1452
Thread: Andrew & Tamra's 818SR EM Autox Hybrid Destroked Long-Rod Build
    Exeter R.I
    I made my own spacers and brackets guys, it was not that much effort. I would think by now they had it down.It looks like FFR might still need to revisit the rack mounting to get it right. You will get it, your doing great so far. You get rings in, I hope that's settled.
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    We got the short block together today (finally)!!!!!
    The start:
    The rings went together much easier this time. We went for 22 thou top gap 25 thou bottom gap per recommendation from JE for our application. Our ring compressor did the job perfectly and they were easy to pop into the cylinders with some pressure by hand.
    The long-rod build made things a little tricky, so we had to go out of order from the FSM. We put the pistons in first.
    We next put in the crank and rods. With the +2mm rods and -2mm crank, it made the piston pins not line up with the access holes. The line up is nearly at bottom dead center on a standard build, and it's past it for this. Therefore, we had to keep the case a few millimeters apart to get everything lined up.
    We were able to shift the crank back and forth to get the pins lined up:
    We next figured out that our c-clip pliers would not fit through the access holes. We sacrificed some needle nose pliers to the task and ground off the tips to fit in the c-clips. It worked flawlessly, especially on piston 3 which was the deepest to reach in to. The added length and narrowness of the pliers was perfect for the job.
    Apr 2014
    Shelton, CT
    With all of the pins in, we separated the case halves so we could apply the silicone and add the gaskets.
    Side bonus, it made putting in the rear main seal an easy task (the FSM has you bolt up and torque the case prior to putting the pistons in, making the rear main seal a difficult task).
    All done!
    Next we will be putting on the heads and measuring for shimless buckets.
    Oh yeah, and for anyone wanting some good general tips on how to assemble a short-block, we found this video helpful:
    Apr 2014
    Shelton, CT
    Time lapse of the short block assembly!
    Exeter R.I
    Nice job!
    Apr 2014
    Shelton, CT
    Last night and today were productive again!
    Got the heads bolted on:
    Gas tank assembled:
    Started to torque the camshafts in to measure for shimless buckets (picked up 4 of Subaru's smallest shimless buckets, 4.38mm). Oh wait, that wasn't supposed to happen......
    Got it out uneventfully, thankfully:
    NOTE: THE SUBARU FACTORY SERVICE MANUAL HAS A MISPRINT. YOU DO NOT TORQUE ALL OF THE CAMSHAFT BOLTS AT 14.5 FT LBS. YOU TORQUE THE TWO SMALLER FRONT ONES AT 7FT LBS. Please learn from our mistake... (and thank you Nasioc)
    Thankfully, the rest of the measuring went smoothly and pretty quickly, so now we can get our shimless buckets (and some new camshaft bolts) ordered.
  7. #87
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Whew, glad you were able to get the bolt out! You two are making amazing progress.
  8. #88
    Apr 2014
    Shelton, CT
    Thank you. We have a slightly optimistic goal to have first start by Christmas, so we are trying to push at it a little each day. The engine keeps trying to set us back though!
    On the bolt, when it broke we nearly had a heart attack there for a while.
    When we first went to torque it (it was the first of the two smaller front bolts), something didn't feel right (we could feel it stretching, whereas the other larger bolts just tightened up and and clicked on the torque wrench). So, we un-torqued everything and pulled it back out, checked it and the head, seemed fine, and then went at it again, then "pop." Crap.
    Luckily, as soon as we went at it with a LH drill the bolt actually backed itself out. We at first assumed it was just a bad bolt, so went at it again with one of the other crankshaft's bolts. It felt the same way (could feel that "stretching" feel again), and that's when we stopped and started "Nasiocing" and found out those were supposed to be only 7 ft lbs. We are just going to start with a set of 8 brand new smaller bolts, just in case any of the others were over torqued in their life due to the FSM's misprint.
  9. #89
    Hindsight's Avatar
    Atlanta
    You are lucky it came out so easy. That almost never happens for me. But usually the bolts that break on me are siezed up and do so on removal attempt. I have always had to drill them out and add a helicoil. Major pain. I have also experienced that sinking feeling of over torquing a bolt into aluminum.
    RE the manual, what year manual are you using? I checked my 06 manual and it does show the proper torque numbers (7 and 14 or something). If you two would like a copy, PM me your email and I will send it.
  10. #90
    Apr 2014
    Shelton, CT
    It is for an 02 wrx, which our heads are. Seems like it is just the instructions for the EJ205 that has the misprint, based other nasioc posts.
  11. #91
    Exeter R.I
    It's off for the 02 bugeye, but than I believe got revised at some point once subaru techs starting breaking them. I prob should have mentioned that, but it has been like 10-12 years since I lived your pain, Great job getting it out, that's not always such a treat. I am hopeing to cart by Christmas, life's been busy lately or I would be driving it around again.
  12. #92
    Apr 2014
    Shelton, CT
    LOL thanks Chris. Any other tips? The ones we found today were mostly lack of torque specs, including the valve cover gaskets (about 4 ft lbs, btw) and a few things.
    We had today off, and our local Subaru dealership in Milford, CT (Dan Perkin's Subaru - speak with Gene if you ever call for parts) got our shimless buckets today, that we ordered yesterday! Also the 8 camshaft bolts and a few other assorted parts. Such great timing since we were holed up due to the snow today.
    We torqued the head bolts for the 3rd or 4th time (ARP recommends re-torquing, and we actually got movement after our initial torque to the 2nd torque, but none after that). We installed the shimless buckets, torqued the cam shafts, and double checked the clearances on the shimless buckets to the camshafts using our feeler gauges - .010 for the exhaust, and .008 for the intake, and we were good to go. Closed up the valve covers!
    Question for the Subaru gurus - do these threaded plugs that we marked in pink go in these locations? The machine shop pulled them out. They seem like they are just filler caps of a sort. There is also one on the backside of the engine where it meets the transmission.
    Next we added a shim to our 10mm oil pump (for a total of 3 shims, not sure if it had been previously modified). It seems like this is an area where everyone has a different opinion of what is the best way to go. From our research, it sounds like the 10mm pump should flow enough oil for our non-AVCS heads (AVCS heads should use the 11mm). The biggest issue is when the bypass valve opens and the effect it has. The 10mm pump is set to open the bypass valve at 85 psi, it drops to 75psi for the 11mm pump I believe. The more oil that is bypassed, the more everything heats up. Also, the risk of the oil beginning to aerate increases as the revs go up, due to the oil bypassing faster and faster. When the oil aerates, it can cause a sudden drop in oil pressure, which would not be good. Since we are planning on revving this engine higher than stock, this is critical for us to get right. Adding shims increases the psi that the bypass valve opens. This puts more pressure on the system overall, but will decrease the risk of us losing oil pressure at high rpms and with our increased bearing clearances. The real test will be when we start up the car and data-log and monitor the gauges. We will adjust the shims and/or the pump accordingly at that point.
    Pulled this off:
    Pulled out the little sleeve to find two shims, added one more, and closed it back up.
    Then we just gave the engine a good polishing
    Just kidding... VHT Engine Enamel did the trick though (We had previously sand blasted it and it still didn't look great, but at least it prepped it for paint).
    We hope everyone has a Happy Thanksgiving!
  13. #93
    Exeter R.I
    Have a happy turkey day guys!! Looking great!!
  14. #94
    Apr 2014
    Shelton, CT
    Came home from Thanksgiving to find Christmas! Wow, and this is the "little" Borg Warner... the S200SX 51mm with .83 a/r. At least we'll be able to ditch the water tank since all 24lbs of it is oil cooled!
  15. #95
    USA
    That's a great turbo, especially for the price.
  16. #96
    Nepa
    whats your plans for the uppipe and wastgate..
  17. #97
    Apr 2014
    Shelton, CT
    Andrew has access to and practice with TIG equipment, but we aren't quite sure yet. We are going to get the engine in and then see if we can fab it ourselves (starting with our Kinugawa twin scroll up pipe). Moore Performance makes a rotated up pipe with a t4 flange solution for the Subarus also that we will check into if we don't think we can do it ourselves (again no guarantee of 818 fitment though).
    Our plan is to run dual EWG's, 38mm TiALs.
    We will hopefully know in a week or so if we think we can make it fit without rotating. The turbo is a little bigger than we expected, lol. Twin scroll should be fun!
  18. #98
    Apr 2014
    Shelton, CT
    Another productive day! We took a few days off for Thanksgiving, so today was the first day of progress since our last update.
    We shaved down the TGV rods a little further and got them put back together. This should allow for more air flow, without throwing any codes or causing any emissions issues. The center rod used to be the same thickness all the way across (we had already removed the flappers and smoothed out the walls previous to today).
    Put together:
    For looping the coolant crossover tube to the hard black return line that attaches to the lower water pump nipple, we decided to cut it down and just run a soft hose to the water pump. As our turbo is oil cooled only, we do not need the other black hardline that runs to the passenger side of the engine.
    The FFR plan would be to loop #1 (from the coolant crossover) and #2 in this photo together (ignore the blue, this was an idea we had that was scratched). FFR provides a u-shaped hose which works on newer 2.5 engines, in which #1 is placed directly next to #2. Not so much on our 2.0 coolant crossover pipe:
    We cut the long tube coming up (#1 in the photo above) and flared the ends. This should allow us to put a soft hose on and loop it directly to the nipple on the water pump. This will bypass the heater core and provide the heated water from the engine back into the water pump (this is a return line) to heat the thermostat, which triggers it to open:
    Installed:
    We wrapped the engine harness:
  19. #99
    Apr 2014
    Shelton, CT
    We mocked things up (no gaskets installed yet):
    I'll just list a few different angles in case anyone needs them for reference (particularly the electrical connectors), and in case you see anything we have done wrong:
    This connector we could not find a home for. Any ideas?
    We will be replacing every rubber hose currently pictured. Here is a very handy list for anyone else doing the same thing:
    http://forums.nasioc.com/forums/show....php?t=2614458
    Thanks to Metros build thread for some helpful visuals as we were putting things together!
    Also thanks to the Simplifying the EJ thread for further assistance! As we will be street registering this car, we will be keeping all of the emissions equipment (or at least the appearance of it).
    We'll be working on the fuel lines next. We picked up an STI FPR and will be running rubber lines in "parallel" format (really semi-parallel, as it will be 2S-2P). We also need to look into what turbo inlet options we have, which is still up in the air since we do not yet know the placement of our Borg Warner S200SX.
  20. #100
    Nepa
    I think it goes to the power steering pump.
  21. #101
    Aug 2011
    Logan, UT
    yep, power steering pump. ups the idle rev's when the pump kicks pressure out (iirc)
    the other thing. the rubber hose that goes to the fitting on the front of the manifold (from the solenoid) that has a whole bunch of random "T"s on it, and that interesting looking black and tan thing.
    this is the EVAP circuit. You can delete a LOT of the random "T"s and just go with the Solenoid from the manifold to the evap line from the tank/charcoal canister. Makes it much simpler and keeps the chance for boost/vacuum leaks down.
    as for the plugs you were asking about. they are all OIL GALLEYS. make sure they're all sealed up good.
    they are also really good for checking oil pressure and temperature. Just saying.
  22. #102
    Apr 2014
    Shelton, CT
    Quote Originally Posted by Samiam1017 View Post
    Quote Originally Posted by Ironhydroxide View Post
    Thanks guys, much appreciated. Guess that one's not getting deleted
    Do you have any sort of a visual that shows the evap line routing you are talking about? We are all about simplifying, but we still need to be emissions compliant.
    The plugs are all sealed up except for one, which we are going to add a t fitting off of for our oil pressure and oil temperature gauges.
    New video from the engine build up. Our Timelapse loves to cut out at the exciting parts, so no intake manifold. But, it is the entire short block to long block assembly!
  23. #103
    USA
    This is going to be a nice high performance setup, ditch those TGVs!
    I have a set of deletes and a ported/polished manifold for a drive by cable throttle if you need it.
  24. #104
    Aug 2011
    Logan, UT
    Nasioc has a write up about it. It doesn't throw any cel. And I highly doubt anyone who understands how the system came stock will blame you for simplifying it
  25. #105
    We would have liked to fully delete them, but this is a for-now compromise, unless our tuner can delete the code without a not-ready status
    I haven't seen anything about a CEL-free TGV delete option.. Do you have a link? My understanding was that it was just an easy code to delete, but CT is picky on not-ready sensors. I'm trying to avoid having to make a shortened version of the TGV rods to activate the sensors.
  26. #106
    Hindsight's Avatar
    Atlanta
    I asked Wayne that question and if we understood eachother correctly, he said ALL codes can be turned off in the ecu (not just cleared but totally disabled) and doing so will not effect readiness code. Might reach out to him or another experienced tuner to confirm.
  27. #107
    Leesburg, VA
    All you'd have to do is drill out the actual valves off of the rods and shave away the metal from the interior runners of the aluminum housing. The rod would remain the same length and would be there to activate the sensors. I believe this is how you delete the valves without throwing a code and I was going to use this approach until I got a tactrix cable. Now I'm planning to completely delete the actuators, sensors, and rods and then clear the codes.
  28. #108
    Apr 2014
    Shelton, CT
    Andrew is going to call a tuner today to ask about some other things, so we'll check on the TGV's and removing "not ready" codes as well.
    Also, I found a diagram that explains which evap items can be eliminated around the "T" section that Iron mentioned. According to Nasioc, deleting these will not cause a CEL and shouldn't give us a problem passing emissions. We aren't 100% sure how closely they "inspect" during the CT inspection or if this would even matter, since it is still uses the charcoal canister, but we are going to try it this way. This is how the JDM ver7/8 STi cars are setup, apparently.
    Tamra
    First autocross 3/29/15
  29. #109
    That's exactly what is pictured above...and is our plan, unless the tuner says it can be taken care of with the Cobb. The flaps are removed, the aluminum divider is cut out.. and I also thinned out the profile of the rods when they're in the "open" position..
  30. #110
    Leesburg, VA
    Ahh, couldn't see your pic - my work firewall blocks photobucket. The uploaded pics and other photo sites seem to work fine though. As long as you've removed the valves and aluminum, that takes care of most of the obstruction. I only want to delete the rods to use the tgv sensor 0-5V input for data logging temps.
  31. #111
    Encinitas, CA
    I installed GrimmSpeed PnP'd TGV deletes; from what I've read, this should be straight-forward to delete the CEL with the Cobb AP3 once I fire it up. Regardless of what the OBDII reports, the visual inspection of our SMOG check would catch a full delete. Hope if works for you! Luckily, with the SB100 option in CA, I don't have to worry about emissions (ironic, huh?).
  32. #112
    USA
    No restrictions...
  33. #113
    Hindsight's Avatar
    Atlanta
    Woah, why does that look sleeved?
  34. #114
    Apr 2014
    Shelton, CT
    We spoke with the tuning shop. Although they can delete the "not ready" codes, we are worried about the visual inspection. We will finish the TGV deletes next winter, after it's road registered
    Also, it sounds like we will be able to get a base-map for our build for initial start-up, so we will proceed with installing the ID1000 injectors!
    Back a few to when we were discussing those oil plugs on the top of the engine that make good ports for oil pressure and temp gauges... FYI in case anyone else is looking to do the same, it sounds like the factory oil sensor, when removed, will not trigger the oil light on the cluster. We'll probably remove that one and just have oil pressure out of one and temp out of the other (there aren't any others that are easily accessible), rather than having to do a T off of one.
    Tamra
  35. #115
    south-central CT
    I wonder if the DMV does any inspection for a "new" car or do you go to one of the stations that do inspections? I had a horrible experience with an inspection station that would not believe me that the Cobb downpipe had a cat in it. They saw a few mods and heard the car and told me to get lost. It would have passed had they not rejected me outright.
    I may have a fitting that you can have that has a tap for oil temp or pressure. It works with AVCS fitting, however.
    Motor looks great. You guys are doing great.
  36. #116
    Santa Rosa CA
    I have always run my oil temp from the oil pan. If the sender is in the block it will get block temp, unlike the coolant temp that has fluid flow around it the oil ports are dead head for pressure so there is no flow and I don't think the temp is accurate
  37. #117
    Exeter R.I
    Oil temp is best in pan guys. KB pan has a port and is a wise investment.
  38. #118
    Apr 2014
    Shelton, CT
    Thanks Glyn! The inspection for kit cars is only at one DMV location in Waterbury, no other options, so we'd better make a good first impression. It has to pass an emissions test separately as well. Do you know what the thread pitch is? We need M20x1.5 to 1/8NPT.
    We were thinking of the recently used oil temp as being beneficial to know as opposed to the reservoir temp, but didn't think about the temp not being accurate. That is something to consider for sure.
    We already have an STI oil pan. We are considering doing the oil temp from the pan, but just wanted to check clearance to the ground. As ours is OEM, it would have to be through the drain plug, which of course is at the lowest point.
    Tamra
  39. #119
    Apr 2014
    Shelton, CT
    We installed our Killer B pickup and windage tray tonight, our new STI oil pan, and our new OEM oil cooler and oil filter. We decided to get a new oil cooler as insurance, since we didn't know the previous history of this motor (plus it had ACL bearings in it when we initially opened it up, meaning it had a bearing failure at some point in its life). After reading too many horror stories about not being able to get the metal particles out, we decided not to risk it (despite the fact that our existing oil cooler did not have any grit come out when I cleaned it).
    In our excitement, we decided to test fit our Kinuguwa Twin Scroll Headers... only to find they didn't fit. They hit the STI oil pan and have about 1/4" before they would reach the heads. Has anyone experienced this? Any ideas on how to resolve the issue? We have reached out to Flatirons Tuning who we purchased the kit from and are awaiting their response.
    The good news is that they sit flush with the pan with the 1/4" gap, so we hopefully shouldn't have too big of an issue with them hanging below the frame rails too far. Does anyone know if the STI oil pan hangs below the frame rails?
    Tamra
  40. #120
    Exeter R.I
    Sti pan does not hang below, the KB pan does barely and my headers kinda lined up with that pan. Uncommon headers usually always have fitment issues even the larger names have fitment issues, you might be able to heat the header tube and bend it just out of the way enough. That's what I do if it's close( up to a 1/4 clearance issue) over that and other mods might need to be done.
