Hey everyone,
For some back story on this, I have owned the car since 2006. I loved the car. Still do really. As mentioned in the title, it is highly modified. Over the years of owning it, I went through and upgraded everything possible. And from the list below, you know I mean everything. All of the mods were designed around making it a better street car and autocross racer as it was a daily driver (highway miles to work) and autocrossed a handful of time per year. I wanted usable power, so the turbo, while larger than stock, still spools up fast but produces about 375-400hp at the crank with the new motor. Full boost (19psi) hits at about 4000rpm. That mated to the RA close ratio 5 speed tranny, and it is a rocket ship.
I blew the stock tranny racing autocross. I worked with my local Subaru performance shop (LIC motorsports) who happened to have a 5 speed tranny with an RA gearset and a front Cusco 1.5 way LSD. It was used, but only for about 6000 miles. The customer that had it decided to go with a 6 speed swap after driving it for a while. After the tranny went into my car, I blew the 2.0L motor. Again, I went to LIC motorsports and had them build me a brand new 2.5L motor based off of their race spec short block with some extra upgrades like billet rods and upgraded springs and valves (can handle up to a 9000rpm redline, but has never been shifted above 7000rpm). A full breakdown of the build is below. I way over built the engine so that it could handle anything thrown at it.
After getting the car back after the engine build, I went through a meticulous break in process. With the money I spent on the motor, I wasn't about to do anything except exactly as directed by the guys at LIC. After the break in, the final tune was done by the head tuner at COBB. Sadly I'm blanking on his name now, but it is the same guy that tunes LIC Motorsports' race car.
Not too long after that, I hit a deer on the freeway. Insurance totaled the car even though the damage done to it was minimal. I had planned on using it as a donor car myself before hitting the deer, so after insurance totaled it, I didn't see the point in spending any money to get it back out on the road again, so it has been sitting in the garage.
Unfortunately, building an 818 is just not in the cards for me right now and I am sitting on a fantastic platform to build a monster of a car. You will not find a better donor car anywhere. Below is a list of everything that has been done to the car, as well as a lot of extras (2 extra turbos for example). There are also a lot of extras that are not on the list that I have sitting in boxes. Prices paid are also listed so you can see the value you would be getting. Extensive receipts have been kept as well. I would like to sell it all as a package. I realize that a lot of the extra stuff and some of the modified stuff isn't really applicable to building an 818, but selling the un-needed items could help finance your build.
Asking $12,000 OBO for everything.
Engine
LIC Motorsports built 2.5L R1 Engine Balanced within 0.25grams - $12,993
2.5L semi Closed Turbo Block
Subaru STi Forged Nitride Crank
Billet H-Beam Rods
ACL Rod/Main Bearings
JE 99.50 Lightweight Forged Pistons
JE Piston Rings
JE Wrist Pins
NGK Irridum Spark Plugs
ARP Subaru Headstuds (11mm)
Power Enterprises Kevlar Timing Belt
Cosworth Timing Belt Billet Guide
LIC Motorsports Timing belt Idler Bearings
STi Water Pump
New Head Castings w/ custom machining
Cam Buckets
Supertech Subaru Turbo INCONEL Exhaust Valves (32x5.96x104.70mm)
Supertech Subaru Turbo Stainless Steel/Black Nitrided backcut Intake Valves (36x5.96x104.35mm)
Supertech Dual Valve Spring 70 @ 35.5mm – 9000rpm Redline (Never Shifted over 7000rpm)
MAF Sensor
STi 565cc “Pink” Fuel Injectors - $400
IHI VF34 Turbo - $1450
Vishnu Aluminum Top-Mount Intercooler - $1000
Go Fast Bits (GFB) Stealth FX Blow Off Valve - $350
APS 65mm Cold Air Intake - $280
Prodrive 3-Port Boost Control Solenoid + Boos Line - $125
Port and Polish VF34 Turbo - $150
Ignition Coils - $420
GrimmSpeed Catless Up-Pipe (black coated, non EWG) - $200
New front O2 sensor - $225
APS DR series 3.5in. Turbo back race exhaust w/ silencer - $1295
Gruppe-S V2 unequal length header - $375
Transmission
Used/Rebuilt (aprox. 6000 miles on tranny at time of purchase) with 5 speed RA Close Ratio Gearset w/ Cusco Front Limited Slip Differential - $3250
RPS MAX Series Clutch with Street Disc. Pedal Pressure = stock + 15%, Torque Capacity = 400 ft pounds - $625
Lightweight Flywheel - $350
STi 5 speed transmission mount - $80
Short Throw Shifter - $260
Suspension
Prodrive lowering springs, 1.5” drop in front, 1” drop in rear, 30% stiffer than stock - $300
KYB AGX Gas shocks - 4 way adjustable compression - $560
Whiteline Bump Steer Kit - $200
Cusco oversized Strut Bar (Front) - $180
Cusco oversized Strut Bar (Rear) - $180
Cusco Adjustable Rear Sway Bar - $200
Kartboy Endlinks - $200
Tuning/ Engine Management
COBB AccessPORT V2 -$695
Custom tune by COBB Tuning - $440
Brakes
Stoptech Big Brake kit 4 piston (front) - $1900
Stoptech BBK 2 piece slotted rotors 328x28mm (front) - $440
Stoptech BBK AXXIS ULT 609 brake pads (front) - $80
Stoptech AXXIS ULT 770 brake pads (rear) - $50
AP Racing 551 Brake fluid
Cooling
Koyo Aluminum Radiator - $480
Samco Radiato Hose Kit - $115
Wheels & Tires
Enkei RPF1 17x9” Black - $1080
Continental Extreme Contact DWS 235/45R17 (brand new) - $600
Rota Tarmac 2 17x8.5” Silver - $700
Toyo Proxes TR1 225/45R17 (worn) - $720
Rota (model unknown) 17x9” Sports Bronze - $850 estimate
Toyo Proxes R888 235/35R17 (worn) - $860
Gauges
Omori Boost Gauge - $150
Omori Exhaust Temp - $170
Omori Fuel Pressure - $180
Some Extras
IHI VF30 Turbo - $950
Stock WRX TD04 Turbo
Stock WRX intercooler
Vishnu 3” Turbo back catted exhaust - $1600
OBX equal length header - $340
Stock WRX exhaust
Stock WRX intake
Stock WRX BOV
Here are some pictures of it so you can see the condition. Sorry, some the pictures are pretty blown out with the light. I can take any pictures anyone would like to see.
image1.jpgimage2.jpgimage3.jpgimage4.jpgimage5.jpgimage6.jpgimage7.jpgimage8.jpgimage9.jpgimage10.jpg
