Results 1 to 5 of 5
Thread: Help finding the thread with Transmission "clunk" noise on accel/decel.
    Houston
    I've search for some time, and haven't found it...I remember reading about the clunk noise and then discussion about the relatively soft OEM mount twisting enough for the steel "hooks" to bump against the mounting ...causing the noise.
    I believe I have this issue and want to read all about it. Please help someone.
    {It would be really helpful if the search feature took one to pages...not just threads}
    fred
    Freds
    I have that problem. The trans mount hooks hits the frame near the holes in the frame. See these pictures.
    Senior Member gwarden's Avatar
    Jan 2012
    Surry Va
    Quote Originally Posted by freds View Post
    fred
    2nd that opinion
    Aug 2012
    Long Island
    After you search and find your thread, use the search thread option at the top of the screen to find the page the result is on.
    Houston
    Thanks guys.
