The unfinished kit I acquired has an older Forte hydraulic clutch setup. The CNC slave cylinder is 7/8 bore (the only size available) and the master is a Wilwood, also 7/8 bore. Should the master cylinder bore be 1" or 1-1/16"? I seem to recall others having issues with clutch arm travel.
