Results 1 to 3 of 3
Thread: 390 header/Bellhousing/driveshaft yoke interference issue
    Member Luv2fly's Avatar
    Aug 2013
    Manlius, NY
    The #8 header tube touches the drivers foot box. The starter area of the Bellhousing touches the diagonal frame support. The front driveshaft yoke hits the crossmember.
    It's a 390 with Edelbrock heads, FFR Hooker headers! and a TKO 600 transmission.
    I have searched all the threads I could find to solve this problem. The motor is as far forward as it can be without the oil pan hitting crossmember. Transmission is mounted with lip down. The transmission mount bolts are as far forward as they can be in the slots of the mount. Not sure if different mounts will do the trick.
    Also, has anyone had an issue with the header bolts in front of tubes #7 and #8? The tube bends are so tight it is impossible to get a bolt in the hole.
    Thanks in advance
    Senior Member Raceral's Avatar
    Stoneville NC
    I'm working on a BB too, just the motor for now. I am watching all the answers to these questions. If you don't get anything here, hit the other forum. BB info is just hard to come by. Is it a MK4
    Al Adkins
    Certified "Kool Aid" drinker
    Aug 2013
    Manlius, NY
    Great idea, thanks!
    I agree, not nearly as much BB info.
    Good luck with your build.
