Results 1 to 10 of 10
Thread: Center diff and Transfer gears
    Aug 2011
    Logan, UT
    So,
    I was thinking today, Most of us pull the transfer gears, center diff and rear plate out of the trans, and do what with them? Toss them? recycle? Probably.
    well, if they're still good I'll buy them off you. I do a lot of Transmission rebuilding, and there's always a demand for cheaper good parts with the 17-25yr crowd.
    Message me if you have your transfer gears and center diff still, with nothing to do with them.
    thanks
    Rusty
    and for reference, Here's a pic stolen from our lovely Mechie3's 818E build thread.
    everything on the ground is what I want. Gears need to be unchipped/broken, and the center diff needs to still have it's snap ring in place.
    Leesburg, VA
    PM sent, just curious what you're offering for these parts and will you cover the shipping to UT?
    Aug 2011
    Logan, UT
    These should fit into a large flat rate box ( I'll confirm tomorrow, but I recall them fitting fine).
    Responded to all PM's thanks guys.
    Nepa
    you still looking for these?
    Hi can any body confirm the small bearing race is not installed in this picture? I either threw it out or it is still installed, I would not think it is due to all the handling from cleaning and painting, thanks Donimage.jpg
    If you are talking about the bearing race that some are accidently leaving in the transmission. Yours is gone.
    Aug 2011
    Logan, UT
    Yeah, i always use new bearings when installing. and Like to use new bearings whenever i'm inside a transmission (some customers want the $800 price cut for used bearings).
    so, no worries.
    image.jpgimage.jpgHey Rusty are you still interested in these parts, pm sent with pictures, thanks Don
    Nepa
    need any front diffs?
    Nov 2012
    Medina, OH
    The center diffs do go bad. Find some sorry bloke who needs one and sell it to him.
    Rich
