Thread: push on to -an fuel line fittings
    Nepa
    I saw a picture yesterday on the forum of push on to-an fittings. Can't find it now. I'm looking for the size or part numbers for for both the feed and the return lines. Thx in advance for any info
    south-central CT
    No problem. Jegs, Summit and others have them. Not only that, you can get different styles.
    This is the Russell fitting I've used. You screw it together. No special tools required.
    JEGS: some plastic.
    Russell Performance. May be same as Jegs.
    Rodger Clark Motorsports.
    I used the Russel part on my gas tank and in the engine.
    Nepa
    Thx guys. Bompus gave me the Russel numbers his build thread is the pictures I noticed thx
    Research Calibrator sponaugle's Avatar
    Portland, OR
    Quote Originally Posted by Samiam1017 View Post
    I am a fan of the Aeroquip Socketless Push-lock fittings:
    The aeroquip socketless hose is very strong and abrasion resistant.
    It takes a bit of muscle to get the fittings on the hose, and it is nearly impossible to remove the fittings without cutting the hose... so those fittings are not going to come out accidentally.
