Results 1 to 10 of 10
Thread: Any Trick to getting these back apart!
    Senior Member Rotorcraft's Avatar
    Sep 2011
    Snohomish,Wa
    This is one of the rear harness plugs.. I know I have to release the "catch" on the side of it, however I can't seem to get this booger back apart.
    I decided I want to rerun the edging I used in the footbox wire hole, and dag nabbit I can't get this one apart. I am pulling only on the plug (both sides) but try as I might it wont come apart.
    Any input would be welcomed!!
    "The I.E." SoCal
    Release the catch, then wiggle, wiggle, wiggle while pulling it apart. New ones seem to be a bit tight.
    __________________________
    Yea, those can be really tight at first. I'll be it didn't go together too easily either, right? For the really stubborn ones, I've used a screwdriver wedged into the catch to hold it open, and then a pair of Channel Lock pliers across the wide part of each connector body. Couple of wiggles and they're apart. Don't pull on the wires obviously.
    Yep! Channel locks.
    Sep 2011
    Snohomish,Wa
    Well I was too afraid I would F it up, so I just worked around it..
    Thanks for all the input guys...
    Here is the end result.
    Thanks again.
    Sep 2011
    Snohomish,Wa
    Thanks again.
    O'Fallon, MO
    I would work on it now to get it apart. Some day you'll need it apart and will not have easy access to it. Once apart use a little dielectric grease on it, and reassemble.
    Sep 2011
    Snohomish,Wa
    Yeah, sounds prudent... Better now than later .. Thanks
    Sep 2011
    Snohomish,Wa
    Success..
    two pairs of channel locks and some wiggling..
    and no damage.
    greased her up and good to go..
    crisis averted..
    Jax Beach, FL
    You need to say the right words when you pull on it. I think most of them have four letters.
