Results 1 to 5 of 5
Thread: Boyd's tank sending unit
    Mar 2014
    Getting ready to order a 33 HR tank from Boyds.
    Does anyone have a source for a sending unit that will work with the FF supplied fuel gauge? My preference is to use it instead of buying a second fuel gauge.
    Member dagall's Avatar
    Ocoee, FL
    Quote Originally Posted by Scot View Post
    Just have to buy the gauge that matches Boyd's. That's what I did and several others did the same. It was easier to source the matching gauge rather than search for a sender to fit the tank.
    Dec 2013
    Cologn MN
    Quote Originally Posted by dagall View Post
    I believe the one you want that matches the factory set up is the AutoMeter American Platinum Analog Gauge Number 1904. Summit is one source, but there are many others as well. http://www.summitracing.com/parts/atm-1904.
    Pembroke Pines, FL
    Dave,
    Just want to verify that the ATM-1904 fuel gauge is the one that matches the Boyd Tank sender...can you comment before I place the order?
    Don
    Dec 2013
    Cologn MN
    Quote Originally Posted by DonC View Post
    Dave,
    Don
    Don, If you are using the factory gauge package, and your Boyd tank has the "0 ohms empty, 90 ohms full" sending unit, then this is the gauge you want. Dave
