Page 3 of 3 FirstFirst 123
Results 81 to 83 of 83
Thread: Headlight Thread - Camry lights (old)
    Harley818's Avatar
    Vancouver BC
    received my halos and glue from retrofit source.
    had to sand off the back of the reflectors to make the HID's fit. The reflector is too thick for the HID's.
    Standard reflector
    Sanded reflector. I took off about 0.25 in.
    angle from bottom of reflector is not square so you need to use an angle tool to check the correct angle when you sand it. I used a belt sander..
    Installed the Halos.. They are white when off, so won't look the greatest when lights are off. But when the lights are on they perform like DRL's and turn orange when signalling to turn (if you want)
    Here they are installed.
    I wired them in with a small copper wire to hold in position attached to the shrouds. and electrical wire runs back through the projector and out the reflector in the back. I used the hole where the low beam shroud was attached.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    Edmonton, Alberta
    Not sure how I missed this, looks good Harley! Have you had a chance to install them yet?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Harley818's Avatar
    Vancouver BC
    installed and they worked pretty good last summer.
    I had the projector cutoffs where I wanted them.
    Now that I've painted and finalized all my body fitting, I plan to revisit and adjust the projector angles a little bit.
    when I do i'll post how it turns out in my build thread.
    Harley
