Page 1 of 3 123 LastLast
Results 1 to 40 of 83
Thread: Stebru84 South east PA 818s #248 build
    Lansdale
    Stebru84 South east PA 818s #248 build {FOR SALE}
    FOR SALE THREAD: WITH CONTACT INFO
    https://thefactoryfiveforum.com/show...ed-and-Insured
    Hello all, I'm starting this thread a little late, I spent more time in the garage than on the computer.
    I Picked up my 818 on Oct 24th 2014. I started the tear down of my 2007 R-Titled Wrx about a month earlier and had it out of the way just in time.
    The donor has ~62k on it. It was crashed hard in the front and rebuilt by a local Subaru chop shop outside Allentown then sold (more on this will come). I bought off cregs list shortly after placing my 818 order it and used it for nearly a year as an extra car, fixing little things and made sure I had a good drive train to start with.
    IMG_20141006_162435.jpgIMG_20141003_152314.jpgIMG_20141003_152330.jpgIMG_20141003_154303.jpgIMG_20141003_162102.jpgIMG_20141004_114907.jpgIMG_20141004_182449.jpgIMG_20141006_162341.jpgIMG_20141006_162428.jpg
    The drive train will go in stock and fairly un-touched, for now. I'll worry about finishing the build by spring so I can enjoy it. Next winter the engine and trans will get some power upgrades and a LSD.
    Lansdale
    Some of the issues I encountered, bent lateral link, and nearly destroying the bushings trying to get that long bolt out.
    The one armed bandit that rebuilt this car must have sold off the 4/2pot brakes and put random, mismatched front calipers on it. Thankfully I picked up a matching set on ebay for cheap. They should be enough for such a light weight car.
    IMG_20141024_085200.jpgIMG_20141024_085254.jpgIMG_20141024_085334.jpgIMG_20141024_090931.jpgIMG_20141024_092807.jpgIMG_20141024_160109.jpgIMG_20141028_155928.jpgIMG_20141028_183154.jpg
    Made the long drive from the philly area and back in one day to pick up the chassis.
  3. Likes wabard liked this post
    Lansdale
    IMG_20141106_172601.jpgIMG_20141107_115248.jpgIMG_20141110_131000.jpgIMG_20141110_135041.jpgIMG_20141110_173151.jpg
    I had one bad wheel bearing so it gave me a good reason to buy a press and replace all 4 and add ARP wheel studs while I had it all apart.
    IMG_20141111_133359.jpgIMG_20141102_161908.jpgIMG_20141106_162919.jpgIMG_20141106_162936.jpg
    Front suspension and firewall aluminum installed.
    Lansdale
    Lansdale
    My good friend Justin at JSC Speed http://jscspeed.com/ hooking me up with some goodies. He helped me find the right pads (since I didn't really know what year my brakes ended up being. Ebay fronts I bought are from 2010, rears are 05) Whiteline lateral links to replace the bent ones. Stoptec drilled rotors and HP+ pads
    I ended up getting one defective Koni shock. It looks like it had a small dent in the top that was touched up with yellow paint. The dent seemed to flair out the top just enough that the collar would not slide down over. A quick call to F5 and they shipped a replacement out very quickly!
    The engine/trans are in. once I finish painting the brakes I can put wheels on and torque everything in the rear.
    I saw someone else using the electrolysis and Arm and Hammer washing soda to remove rust from parts. I must say, I am extremely pleased with how well it actually works. Brake calipers cleaned up like new with minimal effort.
    Brake calipers all cleaned up, I took a flap wheel to them and smoothed out the casting lines and sharp corners. G2 epoxy caliper paint, looking good.
    Wire harness sprawled out on the basement floor for some dieting
    I really started to miss the WRX (and the donuts I did in the snow last year) so I went out and found a nice clean 12 WRX with 24kmi
    Nepa
    where in philly are you located? im located in wilkesbarre area but I have a place in glenside where I stay when I work in philly or nj?
    Lansdale
    Lansdale
    Quote Originally Posted by Samiam1017 View Post
    Lansdale
    ~Dec 1st 2014
    Whats left of the shell. Sold the entire front clip. the rear bumper and tail lights are about all that's left to be sold, recouped about $3K selling off parts to teenagers. And the 180,000mi 2011 Jetta TDI workhorse is upset it has to sit outside.
    Donor car's wheels got some snow tires.
    Had to take a day to clean up and re-organize. The number of boxes is dwindling.
    Pedals and steering column are installed, I have to go in search of a 25/64th for the Rivnuts for the gas pedal mounting.
    Yes I made Vrooom Vrooom noises. The anticipation of go-cart mode!!!
  10. #9
    Nepa
    the company I work for there office and shop is in Doylestown. looks good, faster progress than me. maybe when im in town one night I can come take a look. I didn't like a bunch of stuff so im making to many unnecessary changes.
  11. #10
    Frankfort, IL
    The 25/64ths can be tough to find. I struck out a few times and used a 3/8 to keep things moving on those first few rivnuts before going and ordering a 25/64 on amazon.
    Keep the photos coming. Looks good and I like the new daily driver. Probably would have gone with that white if I bought my car again (dgm 2011 wrx)
  12. #11
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Wow, great progress!
    Tamra
    First autocross 3/29/15
  13. #12
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by billjr212 View Post
    I found the 25/64 in Milwaukee Tools brand at Home Depot.
    Larry
  14. #13
    Lansdale
    Quote Originally Posted by K3LAG View Post
    Larry
    none at my home depot or lowes. But the huge Pep boys had all the odd sizes.
  15. #14
    Lansdale
    12/9/14 got a half day off of work, made more progress.
    Fuel pump and tank installed.
    Calipers and pads installed.
    some space saver spare wheels installed backwards so I can torque the rear suspension under load.
    2WD conversion and shifter brackets installed.
  16. #15
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Looking good - you are moving very fast.
  17. #16
    Senior Member Quiny's Avatar
    Massachusetts
    I hope you remembered to pull out the tapered bearing race, it still looks like it is there in one of your pics.
  18. #17
    Lansdale
    after a very frustrating February, I finally got a couple of warm days of work in on the electrical and she fired right up on the first try!!
    first start video
    http://<iframe width="420" height="3...reen></iframe>
    <iframe width="420" height="315" src="https://www.youtube.com/embed/aRivN83ym-0" frameborder="0" allowfullscreen></iframe>
    http://youtu.be/aRivN83ym-0
  19. #18
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    It's a great feeling ain't it!? Congratulations.
    Larry
  20. #19
    Exeter R.I
    Awesome vid
  21. #20
    Encinitas, CA
    Awesome vid
    Yup; you can't fake that excitement... congrats!
  22. #21
    Apr 2014
    Shelton, CT
    Congrats!!!
    (I think this is my favorite first start video!)
    Tamra
  23. #22
    Puyallup, WA
    Awesome! Great milestone
  24. #23
    Oct 2014
    Denver, CO
    Congrats man! That is too awesome!
  25. #24
    Lansdale
    Thanks everyone, I was shocked when it started, I figured it would crank for some time before starting. And after a ton of "I don't think I need these wires" Clip, clip. The only CEL's are for the removed air pump components and fuel tank vents.
  26. #25
    Lansdale
    First drive!
    Things are starting to come together now that its warming up a bit. The first drive wasn't far, I didn't have the wheels anywhere near aligned, I was just eager to get it off of the jacks and make it move under its own power.
    More panels installed
    Temporary instrument cluster mount
    New motor mounts
    Added a bung for my wide band, and made a nice mount following others lead
    Wheels on and she rolls!
  27. #26
    Lansdale
  28. #27
    Lansdale
    First drive
  29. #28
    San Diego Ca 92106
    Great work. I see your using the standard fuel tank and donor seats. How do you like the fit? It's been said by others that for people over 5'10" that a aftermarket seat or the "Boyd tank" or both should be used. I'd like to use the donor seats if at all possible.
  30. #29
    Senior Member AZPete's Avatar
    Congrats! Subaru seats, eh? I think you and I are the only guys who are using the donor seats and it looks like you cut down the base, right? Nice work.
  31. #30
    Freeport, ME
    Pete, I'm using stock WRX seats too... That is one VERY low 818! That appears to be less than 2 inches of ground clearance. Congrats on the rapid build, you are really moving along
    Dan
  32. #31
    Apr 2014
    Shelton, CT
    Congrats!!
    Tamra
  33. #32
    Leesburg, VA
    Great job! I like the custom cluster mount
  34. #33
    Lansdale
    I'm 6'2" and my head is 2-3" above the roll bar, I put the stock seat in because I was trying to get ready for an auto-x. I ordered the FFR Kirkey seats, they will sit on the floor and give me just enough head room with a helmet to pass the broom stick...
  35. #34
    Lansdale
    I was hoping they would work for me but they won't (6'2"). I used the supplied brackets and didn't modify the seat at all, just bolted them on. I don't think you could get them much lower with modification, maybe an inch or two max.
  36. #35
    Lansdale
    I got it running and just set it on the ground, I didn't adjust the suspension before the little stroll in the driveway. I was exceeded to have it move under its own power
  37. #36
    Lansdale
    I made a quick mount, running out of time getting ready for a Philly SCCA auto-x in a week
  38. #37
    Lansdale
    Warm Weather Update. Body time.
    Making more progress now that it is warm and the shake down auto-x went well. I had to fix a few minor issues.
    Properly vented my fuel tank through a small charcoal canister after blowing the o-rings out of the sending unit because it got pressurized...
    Removed and cut down the front CV stubs, they make contact with the shock near full lock. (now that I have wheels/tires that allow full lock)
    I re-engineered the stock CAT so that I did not have to cut a hole in the body. I cut it all apart and changed the angles. I hope that having the emissions components will help me get it registered, then I'll make a proper exhaust.
    FFR 818s #248 received 10/24/14
    first start 3/9/15 https://youtu.be/aRivN83ym-0
    first gocart 3/28/15 https://youtu.be/0Cq9LLzM_40
    first auto-x 4/12/15 https://youtu.be/4ada081tuks bloopers https://youtu.be/ZnBk0C-9uxE
    Body on auto-x Pocono pa 9/20/15 https://www.youtube.com/watch?v=chwtszG7vyg
    PA Titled and inspected 7/15/2016
  39. #38
    Lansdale
    Wheels and Tires
    ENKI RPF1 in Bronze. 17x8 et45 and 18x9.5 et38 with Dunlop Durezza ZII star 215/40/17 and 255/35/18
    I'm going to still need at least 5mm spacer for the rear. even though I got near the recommended wheel/tire size/offset it is still hitting the rear link. I have a set of 10mm spacers that seem to put the tire "hella flush" with the rear fenders. The fronts are perfect.
    And now the body mock up is going well.
  40. #39
    Boy the red body looks great. Much better than the white, IMO.
  41. #40
    Hindsight's Avatar
    Atlanta
    Love those RPF1s!
