Page 2 of 2 FirstFirst 12
Results 41 to 56 of 56
Thread: Fasteners for body panels
    Richmond, VA
    Found these on McMaster Carr. I plan to use them under the car to attach fiberglass using 1/4-20 rivnuts.
    http://www.mcmaster.com/#90015a410/=10kzmsw
    The head is about the thickness of a washer (.110") and the head diameter is .755". Seems like the way to go for fiberglass.
    Maybe add a little purple loctite for good measure.
    818S - #200
    "To finish first, you must first finish"
    "If the car feels like it is on rails, you are probably driving too slow." -Ross Bentley
    "Never run out of real estate, ideas and traction at the same time."
    Kirkland, WA
    Quote Originally Posted by thall818 View Post
    You may want to throw a nylon washer on so the nylon is against the fiberglass
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Mar 2015
    Belmar, NJ
    I am using riv nut for all panels
    I used 10-32 but would use 1/4 if I had to do it again.
    the 1/4 are easier to align when taking on and off.
    the 10/32 threads are tricky and I had to replace many of the riv nuts that loosed when taking on and off.
    I purchased a good riv nut tool and the installation is super easy
    818S #343 Delivered 5-20-2015
    First Start 10-17-2015
    First Drive 10-17-2017 ( 100 feet back and forth until I can get off driveway)
    First Drive with a non leaking tuned motor 11-12-2015 (wow)
    Passed NJ State constructed inspection 8/30/2016
    AKA Sidewalk bolts. Good idea, I'll take a set similar from Fastenal (McMaster doesn't sell outside USA).
    Good idea on the nylon washers, I was worried a little about the bolt directly on the fiberglass. The only downside is that the nylon washer adds thickness.
    PTFE (teflon) could also be an idea.
    Kirkland, WA
    Quote Originally Posted by insurance guy View Post
    This is one reason I went with Nut Plates and not riv nuts
    Tony Nadalin
    Richmond, VA
    I thought the nylon washer was a great idea as well. Went back to McMaster and found these:
    http://www.mcmaster.com/#90295a455/=10lgt8n
    .281" id
    .734" od
    .064 +/- thickness.
    Total height would be under 3/16"....not too bad
    818S - #200
    Kirkland, WA
    .281" id
    .734" od
    .064 +/- thickness.
    yep those are the ones that I used with my 10/32 nut plates and body is solid
    Tony Nadalin
    Bowling Green, KY
    Nut plates and 10/32's are what I will be using, my nut plates just arrived from Pegasus.
    Kirkland, WA
    Nut Plates (not cheap either) require and little more work and can't be used in blind areas but with a little planning these are great and provide maximum ability to hold
    Tony Nadalin
    south-central CT
    I have said some of this before (this post on my build thread) but here's some food for thought, especially for an R.
    I have cut the sail material off that wraps underneath the frame. I have raised the sails to be flush with the frame. That's about 3/16" which you might say allows the whole chassis to be lowered by that much more, if you work off the lowest point of the car body. Raising it also gives a bit more clearance for the tires.
    I have tabs welded to each side of the frame. I bought the Speedway 60 piece tab kit. Then I just have the two rows of screw heads and nylon washers protruding below the pan/frame, by 3/16".
    I am using these McMaster-Carr .55" d. button flange socket head screws with 3/4" OD nylon washers and nylock nuts. A nylon shoulder washer might be the cat's meow.
    High-quality-of-nylon-shoulder-washer.jpg Then you won't have threads digging into the sides of the hole in the fiberglass.
    I thought about Dzus or other fancy options on the bottom and just didn't see that I'd have the need to access anything on the sides that fast. With the locknuts I don't have to overtighten anything against the fiberglass.
    Mar 2015
    Belmar, NJ
    I never heard of nut plates before. Just watched a video on them and installation
    That is a lot of work 2 rivets for each plate
    Three holes for each screw
    Swiss cheese
    Kirkland, WA
    Swiss cheese
    I guess the commercial air liners are Swiss cheese then. Nut plates require removal of less material than riv nuts and provide more fastening than riv nuts
    Tony Nadalin
    Mar 2015
    Belmar, NJ
    Lol
    I just ordered some
    south-central CT
    Can be spot-welded or tacked in place; then just one hole. Some are sold specifically for that purpose.
    Buy bare tabs, like I linked to, with hole in them. I guess I forget that most have beautiful powder-coated frames they don't want to mess up.
    San Jose, CA
    How close should the body connectors be? I'm a ways away from this step but assume it will be a good number I'm drilling
    .281" id
    .734" od
    .064 +/- thickness.
    For same ID-OD, you could get half that thickness with teflon ones. That's what I'll try.
