Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
Thread: Please Graduate MKIV #7693
    Mustang Convert bansheekev's Avatar
    Morgan Hill, CA
    Quote Originally Posted by Kpt112 View Post
    Hello Kevin,
    My name is Kevin as well and I am really new here to the forum site. First of all your car is spectacular! I hope my car turns out 1/2 as well as yours did. I did have a question regarding the gear shift location. On most cars I see this long shifter with the point where it enters the gear box behind the drivers knee. How did you get your shifter up further? I am guessing it is a factor from the transmission you purchased and where the motor is mounted. I would like mine to be closer to the drivers knee rather than back further. I plan on using a Tremec HD T-5 transmission which seems to be a really popular trans. Any guidance you can provide would be much appreciated.
    Kevin
    See an example below.
    Attachment 38542
    I am using a TKO-600 and got a little creative with the provided shifter instead of removing it and replacing it with a mid-shifter. The mid-shifters are expensive and move the stick forward about 6-7 inches. The stock TKO-600 shifter can be reversed (see picture below) which moves the shifter forward about 2 3/4". I then bought a shift stick from Forte's for a 1999-2004 Mustang GT which is a 5" tall 2 1/2" dogleg shifter. On a Mustang the dogleg moves the shift ball toward the driver - I reversed it to move it away from the driver. After a mock-up I wanted to move the shifter forward about one more inch. I had a friend of mine machine a billet aluminum bracket to move the stick forward that one last inch to make it perfect. It turns out that the Coyote is also about 1" further forward in the chassis than 302 or 351 based engines so you put all them together and you get a mid-shifter without buying and installing a mid-shifter.
    If you are going to use a T5Z, you may not have the ability to do this and may have to go to a mid-shifter for a T5Z to move the shift point toward the front of the car.
    Kevin
    MKIV, IRS/TruTrack/3.55s, Coyote, TKO600, Wilwoods
    Delivered: 1/6/2012
    First Start: 1/19/2014
    First Go-Kart: 2/1/2014
    Graduation: 1/4/2015
    Graduation Thread
    Oct 2014
    San Francisco Bay Area, CA
    This is a great idea Kevin. Thanks! I think this is the first time I read a thread that didn't cost money but saved a few bucks
    I was going to order a TKO600 with mid-shifter but looking at your picture, I think this is a perfect solution.
    Quote Originally Posted by bansheekev View Post
    Kevin
    MKIV complete kit #8523, IRS, Coyote Engine, TKO 600, 3.55 rear end, PS, and a whole lot more! Graduated in May 2021.
    Morgan Hill, CA
    Quote Originally Posted by soaringDude View Post
    Hot rodding at its best... Mix and match parts to find creative solutions without breaking the bank.
    Kevin
    Delivered: 1/6/2012
    Graduation Thread
    No quarter JNC's Avatar
    UT
    Fabulous looking build! I'm really starting to regret my sbf engine choice after seeing your Coyote...
    Member Kpt112's Avatar
    Bucks County PA
    Hello Kevin,
    Kevin
    Attachment 38542
    Thanks for the advice, just ordered my kit today! Can't wait.
    Cromwell, CT
    What a fantastic thread. What a fantastic job. I can only dream that my build will come close to this. Bravo, my friend.
    FFR #8214 -2nd gen Coyote-Wilwood setup-Hydroboost-17" Halibrand-3 Link-TKO600
    2003 Mercury Marauder Vortech V2 T-Trim 518rwhp 11.70 @ 121mph
    Morgan Hill, CA
    Quote Originally Posted by FormulaGod View Post
    Uhhh, 518rwhp Marauder? That sounds interesting...
    Delivered: 1/6/2012
    Graduation Thread
    Sep 2014
    Perth, Australia
    Hi Kev, can you pls advise how you installed your fuel pump and fuel sender removeable panels. Realise you probably used rivnuts, but did you just cut out the carpet slightly smaller and use the carpet edge to provide the seal through the trunk floor, or is there something else? I'm doing my trunk carpet now and like the way you did this.
    Morgan Hill, CA
    Quote Originally Posted by geebang View Post
    Exactly as you describe. Rivnuts in the floor aluminum and sandwich the carpet between the trunk aluminum and access cover. I trimmed the carpet with small 'V' cuts about the rivnuts.
    Kevin
    Delivered: 1/6/2012
    Graduation Thread
