Sorry you had to learn the hard way. Nice of you to share and save someone else the grief.
yeah, i was pretty irritated last night, but hopefully someone else doesn't make the same mistake. In the grand scheme of the build, this is an easy one to fix at this stage. New radiator will arrive tomorrow and should be a quick swap and first start on Friday night or Saturday morning.
3m makes a product called Dura Mix its a 2 part epoxy that will fix holes and cracks in plastic radiator, gas tanks Ive even used it to fix striped spark plug holes (temporary). Good to 500 degrees if I remember. cartridge # is 4747 but you need to buy the self mixing cartridge calking type gun.Sets up really quick and you can sand,grind drill or tap in minutes. Pretty cool stuff.
