Hello all,
This is my first post here and I am, by just about any definition, an automotive novice. I recently inherited a FF roadster built by my father and grandfather, who both passed away. I was not involved in their work on the kit, so I don't have much car/build specific knowledge. I also don't have a lot of knowledge about automotive mechanics in general.
My father and grandfather seem to have more-or-less finished the build. I know that they had been driving it around for a while. I couple of weeks ago I towed it half way across the country to where I live. I fired it up and drove it around a couple of times (boy, what a blast), but the last time I took it out I encountered a problem. While heading down a hill I let off the accelerator. Then shortly before the bottom, I started to press the accelerator again to make it up the other side of the hill, however, I got no response from the engine. We began coasting up the other side of the hill with the engine idling. Eventually we stopped, and the engine stalled (I have to continually give it just a little gas to keep it going, particularly when it is cold). I could start the car, but pressing the accelerator still did nothing and so the car would inevitably stall out. After multiple starts and attempts to rev the engine, the car eventually stopped starting at all (probably flooded?). I took the top off the the carburetor and noted that the two of the four flaps were opening and a small spurt of fuel was dropped into the barrels (the two that were not opening) whenever the accelerator was pressed. Checking these items essentially exhausted my ability to perform roadside diagnostics and so I had the car towed home.
I would really appreciate any theories/speculation about what could have caused the symptoms I described. I really want to get to know this car (plus I don't have a ton of money) and so I would like to try and tinker with it myself and any leads forum members could provide would go a long way. Again, I don't know much about cars so please use layman terms as much of possible.
Thanks!
