818 Junkie...
Oil pressure switch, What are you doing?
I really like having an accurate gauge. On my Roadster I had a mechanical one with SS line to the gauge. It quickly exposed that I had pressure problems. A Milodon road race pan and pickup, along with a blueprinted Melling standard pump and proper non restrictive race oil filter quickly fixed that challenge. I never had a pressure problem again.
What are you doing on your 818 to monitor the oil pressure and how is it working?
Right now I have a stock pan and all, but still want instant feedback on what is going on with the oil pressure.
Pictures and pro/con feedback is appreciated!
Stuke
818R For Sale!
818R Sale Thread
PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
Administrator
Bob, did you want to add a gauge to your dash?
818 Junkie...
Not sure, but wondered what others are doing. My initial thought is a panel with canbus, but those things are expensive!
818R For Sale!
818R Sale Thread
Administrator
CAN bus dash only is $1100
I added a pressure sensor to the galley and will run that into my data logger and run a virtual dash (could also run a stand-alone gauge)
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
818 Junkie...
Thanks for the feedback Tony, what spot did you use, and did you just use an adapter to get to 1/4 NPT?
Could one signal be wired to two inputs, say the ECU for logging and a dash gauge?
818R For Sale!
818R Sale Thread
Can we monitor oil pressure using one of those bluetooth ODB2 dongles???
Just re-read my Cobb manual, says you can monitor anything in the ECU does that include oil pressure?
Administrator
Originally Posted by
RM1SepEx
Not since the Subaru only has an oil pressure switch instead of a true pressure sensor...
Gonna have to add a sensor and gauge...
818 Junkie...
Yep it is just an on off switch.
It worries me as oil pressure is pretty important and there is no way to monitor it. I most likely will go with changing or adding a true pressure sensor, I can then wire it to the Megasquirt and it can monitor, log, shut down if needed, and send the info out the canbus to the display.
If you are using the stock ECU, you will have to keep the switch if you can't turn it off completely, and run a seperate sensor to a gauge.
Wayne can help steer you and get you the correct parts.
818R For Sale!
818R Sale Thread
Administrator
RM1SepEx
There is not much room under the alternator so you may have to remote mount the sender
Wayne, what are your thoughts on using one of those sandwich plates between the oil cooler and filter. Is it a good way of measuring pressure and temp? They seam cheap on ebay:
http://www.ebay.com/itm/Oil-filter-s...3d9227&vxp=mtr
Administrator
buy a quality billet one if you do buy one. You will probably not need an oil cooler unless you are running an 818R at the track. I have a customer that was at Sebring last weekend and was datalogging pre and post AWIC temps as well as oil temps. The highest oil temp he saw was 250°F at a track with lots of straights. You are not going to need a big oil cooler and it will need a thermostatic bypass. And then you can run a remote high flow race filter instead of the little Subaru one.
Wayne Presley
I'm re-using the stock oil cooler (or heat exchanger) that comes with the EJ257. I agree it is probably not necessary for street driving but I'm keeping things stock in that area. I just wanted to know if one of those plate would be adequate for measuring oil pressure and temp (considering I'd like to retain the stock oil cooler and filter location). The one I posted is machined from billet aluminum and blue anodized, it's just not necessarily a name brand - all I'd be using it for is the two bungs for sensors. Thanks for the input.
bstuke
I used a galley plug, the plug was under the intercooler (see the picture when you look at the galley plug from ProSport), I left the factory sensor in (under the alternator), I used a galley plug ( http://prosportgauges.com/subaru-oil-galley-plug.aspx )with 1/8 NPT then used a 18" grease gun hose with 1/8 NPT coupler on to a single wire pressure sensor (http://prosportgauges.com/performanc...re-sender.aspx ) so all-in-all like $35
Tony Nadalin
Administrator
I would use one of the other oil galley plugs for oil pressure and weld in a bung on the stock pan for oil temp then. Like he^ said 10 seconds before me but I'd use a braided hose instead
STiPWRD
I'm using a remote oil filter mount that has a 1/8 NPT on it for either pressure or temp, I will use it for oil temp (before it heads off to oil cooler). I also wanted to be able to get to the oil filter w/o having to remove the under the engine aluminum.
Tony Nadalin
FFRSpec72
That looks like a great option, thanks Tony & Wayne!
818 Junkie...
FFRSpec72
Awesome feedback Tony, thanks. And it is something even I can't mess up...
Cooler location is awesome too.
818R For Sale!
818R Sale Thread
Is there an under engine aluminum panel supplied by FFR? I can't find one.
tmoretta
If you bought the diffuser then you should have received the aluminum, I had to call as my diffuser did not come with the aluminum, seems there was an issue with the packaging of the diffuser not including the part number for the aluminum
Tony Nadalin
I used the OEM oil pressure light switch location as my oil pressure. I bought a plug with the correct thread that inserts into the block. It also had a 1/8 NPT hole milled in the center. Since it was close to the alternator, I bought a little 90 degree 1/8 NPT elbow and attached the oil pressure gauge to that. Fits perfectly and clears the Alt.
For the oil temp- I used the rear port under turbo with appropriate VDO sender that actually was the same size M bolt and thread pitch- (easy peesy).
Tmoretta- I had to call them to send me the under motor aluminum.
Thanks- Chad
FFRSpec72
same here, called and they shipped it right out
I did not order the rear diffuser, only the front. I guess I am not eligible for the under engine aluminum. Would it be advantageous, aero wise, for me to order the aluminum panel? Also, for the large front panel under the radiator, what is general opinion on the pre-cut louvers? Should these be opened for extra cooling, will they vibrate or rattle off, should they be fixed closed? I am also noting a space/opening between the under rad. panel and the under battery panel - just under the steering rack. I am wondering if this opening will disrupt air flow beneath the front of the car. Anyone closing this off?
C.Plavan
What was the thread size into the block for the pressure sensor switch?
JB91710
M18 x 1.5
You can buy them with the 1/8" NPT on eBay, but I like the Prosport PSNUT the best. Or the Prosport PSNut Remote Kit. A bunch of vendors sell them, just Google PSNUT.
Just the adaptor: https://www.rallysportdirect.com/par...hreaded-center
Remote Kit: http://www.iagperformance.com/Prospo...p/psropkit.htm
Here's a list of Subaru Thread Pitches. I have it taped to the wall in my shop for quick reference. : https://cobbtuning.zendesk.com/hc/en...re-Information
Owner: Colonel Red Racing
eBAy Store:
http://stores.ebay.com/colonelredracing
818R ICSCC SPM
So then - you disconnect the oil pressure light switch and replace it with a pressure gauge switch? Does this cause the light on the dash to stay on? Is there a way to connect both sensors to the same (behind alternator) location?
Administrator
You can run a T, get a dual pole sensor (switch and sensor combo) or leave the oil light wire disconnected which will not have the light on the dash.
Sgt.Gator
I'm referring to the oil pressure switch which is either 1/8"NPT or BSPT.
JB91710
The Subaru oem adaptor is M18 x 1.5 with a 1/8" BSPT thread for the switch. Since no one else makes 1/8" BSPT sensors, you can use the PSNUT M18 x 1.5 with a 1/8" NPT thread to use aftermarket gauge sensors.
eBAy Store:
818R ICSCC SPM
Sgt.Gator
I believe you're talking about an OEM Galley Plug location. I only have access to one on the front EZ30 engine. My alternator covers the rear one. I barely have access to the OEM switch location on the rear engine and the front one is accessible. The adapter in the first photo is NPT, I think. The OEM hole is BSPT, I think.
What I'm having a hard time finding is M12 1.5 - 1/8"NPT for the Water temperature switch location and a M20 for the oil pan drain plug that will fit the thick VDO sensors. I need over 5/16" and most are smaller than 1/4".
I understand that the EJ208 engine has three oil ports. I have found the one near the turbo (have adapted to add an oil temp. sensor), and the one behind the alternator (original location for the oil pressure sensor).
Where is the third?
tmoretta
Where is the third?
I think the EJ257 is the same as the 208, but not positive. Here's a pic that shows the ports. Note the one in the top front where the oem oil pressure switch is installed is not marked.
The other three on the top of the block are very hard to use because the hard water pipe mostly or completely covers them. But they are there if you are creative.
eBAy Store:
818R ICSCC SPM
So it looks like any/all of the hex plugs right?
Almost. On the bottom of the block at least one is water/coolant.
eBAy Store:
818R ICSCC SPM
Yes, I love Technology
If you guys are ever in a pinch for an adapter, we make a decent selection of M18 to NPT or PT, M20 to NPT or PT, NPT to NPT or PT, and a few others.
