Coupe heat and AC
Hello, trying to mock up my dash and figure out where everything is going. I'm working on the AC now and can not for the life of me figure out how to mount the evap box and route all the hoses? I have the FFR vintage air kit (Gen 1 coupe). I have the unit mounted but when I put the defroster duct on the passengers side of the dash it come down right on top of the 3 holes. I can't seem to see how you guys get this to fit? I have seen several pics of the units installed but none with the ducts attached. If anyone has any of those that might help. I did see an idea about making a troff for he defroster and only having one duct so that's an idea too.
Fordolet
I am building a gen 2. I had the same problem. It is very tight. I ended up deleting the heater hoses and just running defrost and vents. I can have the heat come out either one. Of course I live in Florida and heat is not used much here . LOL. Check out my build thread it may help. Also check out other threads it was a help to me.
