Results 1 to 4 of 4
Thread: Which Manual R&P For Mk4 and pin drive?
    Breeze or FFR, doesn't matter. Prefer 18:1 ratio
    The FFR unit has rack extenders installed to improve bump steer geometry. Breeze offers them with extenders or without. With either rack when going to pin drive width you will probably find that you need to use the short outer tie rod ends that Breeze offers.
    Thanks Jeff. What if I already have an aftermarket bump steer kit?
    Ok I found the rack extenders in the kit. That part is clear.
