Results 1 to 8 of 8
Thread: Mechanical fuel pump
    Jan 2015
    St Catharines Ontario Canada
    Im a newbie. I'm going to run a SBC has anyone used a mechanical fuel pump?
    Fresno, CA
    I have used a mechanical fuel pump in three builds with success. All were Fords, but the Chevy should be similar.
    Doug
    Jan 2015
    Thanks Doug.
    Feb 2013
    Xenia, OH
    I am running the SBC with mechanical fuel pump. I did NOT use the FFR fuel lines though. I wanted a little more flow so I went with a roll of aluminum line from Summit. There are some pics on my blog. What are your questions? I can take more pics if needed,
    FFR HR #530
    Jan 2015
    What size of line did you use and how much?
    Feb 2013
    Xenia, OH
    3/8, bought 25', was MORE than enough. Super easy to form and bend. I ran braided from the hard to the tank, and hard to the pump, then braided from the pump to the carb. Used AN -6 to hard line adapters. Let me know if you want some pics.
    http://www.summitracing.com/parts/aa...0180/overview/
    FFR HR #530
    Jan 2015
    I'm not ready for photos. I'm just starting to build the engine. I want everything ready when the kit is ready. Did you run a 700r transmision? What did you use for a kick down?
    Feb 2013
    Xenia, OH
    Yes 700r. After talking with my trans rebuilder and reading online, that kickdown is crucial to the life and performance of the tranny. I am using a Lokar kickdown cable. I decided to add the TCI constant pressure valve body to the trans. This eliminates the need for the minute adjustments in the kickdown cable for proper pressure. Obviously, the kickdown cable still acts as as that, but does not control the shift pressure.
    http://www.summitracing.com/parts/tci-376020/overview/
    I also went braided lines for the cooler, there are some pics on the mounting on the blog.
    FFR HR #530
