Heavy undercoating, by itself, won't do it?
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
I guess it depends on how heavy, but I had 2 coats of undercoating underneath my roadster fenders and got stars. Once I added stiff foam I got no new stars. Perhaps the roadster guys know how many layers of undercoating will work but I just want to be sure.
When I mounted the front fenders I noticed that there is an opening in the headlight bucket that would collect crud thrown by the tire - rattlesnakes, geckos, small tourists in my case, perhaps you'll get mud and salt. There's also an opening above the bucket for crud to enter the headlight cavity. The left photo shows the openings. I used pieces of the foam yoga mat to cover these openings. The bottom piece is riveted between the bent edge of the aluminum upper piece that holds a flexible foam piece to contact the fender. I also added foam to the top of the front wheel well panel because the bulb seal did not seal against the fender tightly. The middle photo is before I mounted the fender and the right photo is with the fender mounted. I later sprayed the aluminum piece black and trimmed the foam so it doesn't ripple.
Thanks for the heads-up Pete.
I wouldn't have known about the star cracks from stones.
Harley
Bought 2002 Donor Jan 2014
First Start Jan 18, 2015
First Drive Feb 14, 2015
AZPete How thick was the mat you used? The one I have is about 3/16 in thick. Is that too thick?
