Results 1 to 4 of 4
Thread: wiring rear lights....HELP
    Senior Member LuckyWinner's Avatar
    Fort Huachuca, Sierra Vista, AZ
    So I wired the left rear lights as told as below:
    I'm writing this up as Ron Francis wire on left and the Light wire on the right:
    Brake lights
    Purple (Brake)-> Green
    Tan (Tail light)-> Red/Yellow
    Black (ground)-> Ground
    Turn Signals
    White or Yellow (Right or Left Turn) -> Green
    Tan (Tail light) -> Red/Yellow
    Black (Ground) -> Ground
    The green wire on each light is the bright element and the red/yellow wire is the dim element. You need to tie the tans and black to both lights, but it will light up all 4 as tail lights, the uppers as brakes and the lowers as turn signals.
    So far I have just hooked up the left side. Upper brake light is always on, even when key is out. Turn signal working. Bottom light comes on when head light switch is pulled. Lower light doesn't come on when brake pedal is pushed. Any ideas?
    Owner MK4 7642RD, 393 stroker, Gordon Levy Super Alloy T5, HDX Clutch, Moser 3.31 3-link with disc brakes, 17" Bullit wheels, NT05's, Seat heaters donated by WarmSeats.com, door panels donated by Herbs Door panels.
    Master Builder
    Long Island, NY
    I answered on the other forum
    Kenny
    Fixed it. button that hits the brake pedal was not pushed in far enough to turn off light.
    Master Builder
    Long Island, NY
    ok glad it worked out
    Kenny
