Thread: Lokar DBW Throttle for Coyote
    Senior Member E-Ticket Ride's Avatar
    Huntington Beach, California
    Question Lokar DBW Throttle for Coyote
    I think I have seen a photo or two of folks who used the Lokar pedal instead of the FoMoCo one that comes with the engine controls pack for the Coyote. I was starting to dope out the layout of how to mount the factory pedal, and I decided I really don't like the cheap plastick look next to the Wilwood pedals (That damn "good idea fairy" strikes again!) so I wanted to find out from those that have used the Lokar throttle if there are any mounting issues to the chassis or connection issues to the controls pack.
    Would like to have a bit of a clue about challenges before dropping more $$
    TIA
    Confidence: The feeling you have before you truly understand the situation. FFR 7652 Mk IV Base Kit w/IRS: ordered 10/19/2011; Arrived 11/19/2011. Coyote, Trans & headers Installed 9/11/17. First Start 12/19/17, First Go-cart 3/2/18. Aligned and go-karting. Working the interior now. Happy customer of FFR, North RaceCars, Forte's, and Breeze.
    Chris Lewis
    Senior Member DaleG's Avatar
    Mar 2013
    Chris, I'm one of those that went with the Lokar DBW. I'm please so far, but have only had a brief go-kart ride. Another user found some response issues, which Lokar has since tweeked, and he reports it to his liking. So all seems fine. Installation is easy (make a bracket), and you have a whole range of pedals to choose from.
    Thanks Dale. I went with the Lokar updated DBW module. Hope to get the plate fab'd up this coming weekend.
    CL
    Chris Lewis
    Member unrealmach1's Avatar
    May 2016
    Woodhaven, MI
    Just wondering if anyone has the part number for the Lokar DBW assembly that is best suited for a MKIV Roadster Coyote build?
    Quote Originally Posted by unrealmach1 View Post
    The Ford module part numbers are BDBW-FORD01 (silver) or XBDBW-FORD01 (black). Same part other than color. Comes with a pigtail that needs to be wired to the Coyote harness. Then you add a pedal assembly. There are a number of choices.
    Member 3dGuy's Avatar
    San Jose
    has anyone had success with the lokar on the 2015 coyote. I have it wired per the diagram but it doesn't seem to respond. stock peddle worked fine.
    My build site : www.ScootinThunder33.com
