Results 41 to 80 of 86
Thread: Jason's 33 "Scootin' Thunder"
    Member 3dGuy's Avatar
    San Jose
    Motor_Freak, here is the latest update, been so busy i don't make the time to post.
    6tdart, I thought about the olive grab at first but like a bit more of the flashy aluminum that was common on other bombers over the pacific. May not be accurate but will look great as a car. The bomber gauges there are actually the frames that i plan on putting in the car with a different gauge face. I love the look. I'm even trying to source a asi gauge, artificial horizon, and other gauges to add a bit more interest. Just sourced a few nice push buttons for the the power steering, and other elements of the dash.
    Over all the build has been going well. I just need to run the fuel lines, wire harness, brake lines, and a few other small things here and there and ill be in need of an engine and stage 2. I'm surprised i'm this far ahead of where i thought id be. i sent a few parts out to be chrome plated and hopefully will have them back this week. (grill mounts, engine mounts, alternator relocation mount) the power steering and coyote modification have been installed finally.
    in the mean time im working out new "ejection seats" for the car. I like the kirkey seats but they just don't have the right aesthetics that i want for the car. Since i have the time why not. I'm basing the seat itself off of the seats i already have and the headrest and other features are based off of this ejection seat.
    along with the seat i'm doing a kinematic study for a new trunk hinge so i can open the trunk without needing to dissemble the trunk bulges and not have them hit the roll hoops
    hinge study
    current state
    My build site : www.ScootinThunder33.com
    San Jose
    back from the chromer
    San Jose
    needed to take out the trash, made a quick walk around on my way back.
    https://youtu.be/CmSG9UHKVFA
    San Jose
    one last update for the night
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    What software do you use to do your design work?
    Robert
    San Jose
    My day to day software is Maya and vray for modeling and rendering. As for the kinetic study that was done with autodesk forceEffect motion. The seat and and parts that will end up being fabricated I create in solid works.
    San Jose
    Here is where I ended up with the seat tonight. Still thinking about how to mount the chair to the floor and if it should be an adjustable seat.
    Quote Originally Posted by 3dGuy View Post
    Thanks!!!
    Going to look in to some of those.... although not for work....
    Fresno, CA
    Jason, what chrome shop did you use?
    Doug
    Built FFR5196 MKII in 2003, 427w
    Building FFR0058HR, Edlebrock 347-AOD
    San Jose
    Quote Originally Posted by 68GT500MAN View Post
    Doug
    I went to superior chrome in San Jose. Only took a couple days to get the parts back.
    San Jose
    Update: seats
    To quote dock Brown " Please excuse the crudity of this model."
    , just finished the mockup of the seat, found out I miss judged the back height with cushion in and seat depth. But that's what this was for. And Meng helped model the seat for me. Made from layered chipboard and pop rivets.
    San Jose
    Minor update, stage 2 ordered, now just finalizeing design. Better idea for windshields.
    San Jose
    I think this will be the final design for the seat...
    Don't you need slots for the seat belts around the hips? Or will they fit round the outside?
    RJ
    Feb 2013
    Xenia, OH
    Couple of things, you have nice ideas, don't completely design the mounts for your seat until you have the waterfall in (made that mistake) and can check the layback, and check with your DMV on the windshield idea, would hate for you to make it and find out they won't certify.
    FFR HR #530
    San Jose
    Quote Originally Posted by j33ptj View Post
    RJ
    Yes, once i build the seats and get final height and placement worked out ill figure out the best place for the lap belts.
    Quote Originally Posted by maczter View Post
    I should have the waterfall soon so ill be able to take measurements then. at the moment i have things based off quick measurements from another kit. Ill make a new mockup of the latest seat after i get my stage 2. I spoke to a local custom windshield builder and was told its easy to get dot approval for this but will defiantly double check regulations before pulling the trigger. I have the windshield on order so i will have that just in case.
    San Jose
    did a quick check and the only thing it says is that the windshield must be made of safety glass, and have self wiping wipers, one on the left and right unless one does both side to meet the required wiping area.
    http://www.leginfo.ca.gov/cgi-bin/di...le=26700-26712
    San Jose
    Update:
    Stage 2 is here!
    Haven't had time to start on stage 2 but have been working on finally building the seats. Ended up taking a class at techshop San Jose to use the water jet cutter there, and after 3 solid hours of waiting for the machine to cut my parts I finally getting to see the seats realized. Just tonight I started bending the flat patterns into the final parts.
    I can't believe it but I got my hands on a 2011 coyote cheap. There is possible damage to one of the cylinders due to superchager misinstalled but worth the money even if I just use it as a mock up engine waiting for the fin one. Still need to get it looked at to see if it can be salvaged. Got the 2015 plenum cover from another seller real cheap as well. If only I could find a t56. Fingers crossed
    It has been unseasonably muggy the last month making working in the garage miserable. Once that changes my fiancée probably won't see my for a while.
    southern NJ
    Wow great deal on the engine. Keep up the great work.
    Brett
    San Jose
    Nearly done with the seats, here's the first one clamped up. Does anyone know anyone that can create the cushions?
    San Jose
    I Finally got the 2015 coyote engine after selling the 2011 engine i had picked up. I'm noticing a few difference but one seems like it could turn into a real problem. I'm hoping I'm wrong. i don't see this part at the back of the engine in any photos or referencing in the installation guide for the coyote for the 33 and i didn't see in on the 2011 engine that i had. What is this part and do i need it. It seems like it would cause an interference to the firewall. In the manual it says that the fit back there is so tight that you might have to grid down some of the bolts and if that's the case i don't see how this engine will fit since this part sits proud of the back of the engine. Any help or incite will be greatly appreciated.
    San Jose
    About time for an update. I figured out that there is no way to use the stock intake for the 2016 coyote so i replaced it with a boss 302 intake. I finally took the plunge to cut the alternator boss off of the engine block. It took about an hour but there is no going back now. The T56 Mag finally is here along with the rm-8080 bell-housing. the boyde tank is installed now and plumed although i will need to find a way to rout the hoses behind the waterfall so they dont bind or pinch. I cant wait to get the engine in but sadly still waiting on the flywheel stretch bolts and the correct slave mount for the t56 clutch fork. Making alot of progress lately and all it took was to cancel my cable.
    San Jose
    Engine is in! Progress!
    Looking GREAT! Those seats are insane. Any chance of you trailering it down to HB in April?
    San Jose
    I would like to. just depends on work and where the build is by that time. im hoping i can get thingsa in time to possibly drive it down instead of trailer it. Might be dreaming but still will shoot for it.
    I have to say the fabrication work on the seats is amazing. I am totally stoked with your build
    San Jose
    Thank you. Its been a real learning experience building the car and these seats. Looking at how the seats are fitting now that i have the full body i might have to change the curve at the back of the seats to better match the final seat height relative to the rear waterfall. still deciding how high the seats really need to be.
    San Jose
    I thought id post a small update. The remote oil filter has been nothing but trouble to place and rout but i think i found a solution. Ford is finally shipping the control pack for the 2015 engine and hopefully i should get it in a few weeks.
    San Jose
    one last thing, , gauges
    A lot going on with your build. The seats are really cool! , you put a lot of work into those. Great job!
    Reminds me of when I was in the Navy back in the 80s as a avionics tech.
    Those gauges look familiar, but I can't think of the brand right now.
    Keep up the great work. Look fwd to seeing the windscreens.
    San Jose
    Thank you. The gauges were custom made by classic instruments Moal and v8 speedster gauges. I sent them some rough designs based on the two gauges that i likes from them along with the orange accents and simplified text and about a week later this was the end result.
    Ah, I thought they might have been the Moal Bomber series, but I didn't see the Moal wing logo in them, so I wasn't sure. Wow a week that is a really good turn around. Classic Instruments does some really cool stuff.
    The more I look at those gauges, now that I know what to look for, I can see the moal and V8 speedster touches. Very Nice
    I have a question for you, but I'll send it in a pvt msg.
    She looks great! I really like the gauges, and they fit the theme you are creating perfectly.
    I enjoy reading your updates, and seeing your progress.
    Thanks for posting, and for the inspiration!
    Jan 2016
    Glad I found your build thread, thanks for the help on the FB page. Your build looks great!
    San Jose
    It has been awhile since my last post so i thought id update. I finally have the car up and running and I'm currently in the process of getting the car registered. First trip to the DMV went well and just need to get the chp inspection done and I'm street legal. Here are a couple starts of the car. If you wondered what the new factory five baffled mufflers sound like on the coyote click below.
    second start, no mufflers
    https://youtu.be/xPQ-VT_LIGM
    mufflers start
    https://youtu.be/xfWMp87mR-c
    mufflers idle
    https://youtu.be/BRSyLMHRCGY
    San Jose
    It has been a while since i posted so i thought id add a few photos and videos of the current progress. I have since go carted the car twice and getting ready to put the body on for door fitment. once that is done ill be able to get the registration completed and on the street. Things that have been built since the last post:
    Seats have been brushed and powder coated, starting work now on a wind inspired center console, molded the two areo screen fairings, starting the boss 302 intake hood relief, fabricated and added an assess door for the fuel pump, completed the aluminum dash and gauge inserts. still cant wait until i can take this thing out on the road when ever i feel like it.
    Two videos of the first and second drives:
    First: https://youtu.be/hjflbNXkMmw
    second: https://youtu.be/QKvWzhRAYng
    San Jose
    A couple more from the weekend, Body finally back on
    San Jose
    I thought id give a bit of an update. Getting close to being street legal. a couple recent drive videos as well.
    3rd gear
    https://youtu.be/gyFgNrjmy8Q
    full drive
    https://youtu.be/V3o05h2wi7U
    San Jose
    Its getting close to a year since my last post so i tohught id post some update photos. still a few months of work left to get it finished but its on the road, street legal, painted, and a blast to drive.
    Ol Skool
    upstate NY
    Looks great! Awesome job on the modifications. Thanks for posting the update.
