Results 1 to 28 of 28
Thread: Bob_n_Cincy Head Light install procedure
    To all my 818 friends.
    As Promised, below is a video of how I installed my headlights.
    Disclaimers:
    It worked for me. May not work for everyone. YMMV
    My body is a 2013 version, may not match what you have.
    I made the video a 3AM by myself.
    It's about a half hour, sorry for the length, I should have edited it and taken out about 10 minutes.
    Let me know your thoughts.
    [xxxxx=youtube;QlPaGiM453c]https://www.youtube.com/watch?v=QlPaGiM453c&feature=youtu.be[/video]
    Senior Member AZPete's Avatar
    Nicely done, Bob. I'm sure this video will help some guys. I wish I had seen this before I struggled to mount my headlights.
    To do this properly it's necessary to wear a Zero db shirt, right?
    Leesburg, VA
    Great video Bob, nicely done
    Mechie3's Avatar
    I'll be honest, I wasn't going to watch the video at work but I clicked it just to see the shirt.
    I'll have to watch the rest at home (even though the office appears 1/2 empty).
    Mechie3's Avatar
    Just watched the whole thing. I like the rubber gasket idea. I was thinking last night it needed something. I hadn't thought to use extra wide material to adjust for the variance in the gaps.
    Thanks Pete, Yes 3x Zero db Shirt required.
    Thanks Stipwrd, In school I was very shy and hated to get up in front of a class.
    That has gone away as I've grown older.
    Jan 2012
    Surry Va
    Thanks Bob this gives me hope that I might get past this task
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Nice job Bob!
    Larry
    Frankfort, IL
    Great video. Thanks for posting!
    Is this roughly equivalent to what you got for the rubber edging?
    http://www.mcmaster.com/#8507k83/=wdlb3b
    Puyallup, WA
    i used these white door trim due to having air voids between gel coat and fiberglass. The match up is pretty darn close.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Quote Originally Posted by billjr212 View Post
    That is very close to what I used on the bottom. What I used looks more like style #3 on the MMC page. No clue where I got it. I used it to prevent wire chaffing in electrical panels 5+ ears ago.
    on the top I used:
    http://www.mcmaster.com/#8507k43/=wdlrm5
    Kurk, Send a better picture of your side scoop.
    Puyallup, WA
    The scoop is just poster board. I want to get a rough idea of what itd look like. Heres a better pic of my headlight tho.
    anderson
    Bob,
    Thanks alot for the great video here. I wish there were more like this one to help everyone tackle the body that is a shortcoming in the manual.
    kerry in indiana
    Lansdale
    Thanks for the video, I found it just in time, I'm going to start my headlight install tomorrow!!
    FFR 818s #248 received 10/24/14
    first start 3/9/15 https://youtu.be/aRivN83ym-0
    first gocart 3/28/15 https://youtu.be/0Cq9LLzM_40
    first auto-x 4/12/15 https://youtu.be/4ada081tuks bloopers https://youtu.be/ZnBk0C-9uxE
    Body on auto-x Pocono pa 9/20/15 https://www.youtube.com/watch?v=chwtszG7vyg
    PA Titled and inspected 7/15/2016
    Kirkland, WA
    You can get a longer length here if needed http://www.oreillyauto.com/site/c/de...8.oap?pt=N0546
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Kirkland, WA
    Bob, how timely as I was just doing my rough fit this past weekend and now ready for final fit ...
    So question, the fender meets the font bumper/headlight assemble, the fender has a ridge that extends beyond the end of the fender, does that get cut off or does that get tucked under the front fender/ light assemble ? I have it tucked under right now but that does not seem right
    Tony Nadalin
    Hi Tony,
    I left the tab on the nose of the fender.
    I thought it helped with the alignment there.
    Kirkland, WA
    Hi Tony,
    So does the light sit under the tab or did you have to shift the light over to accommodate the tab? In my picture I shifted the light over but I'm not sure that is correct.
    Tony Nadalin
    Hi Tony,
    Here is a picture of my head lights from the bottom side without the buckets installed.
    II circled the tab.
    Feb 2013
    Bowling Green OHIO
    wow, it would be great if all the tricky installation items had a video like this one. thank you Bob!
    I have my panels fitted (clamped in place) about ready to put my buckets in and i am thinking my front bumper still needs to go down some. currently it is below my tube frame in front about 1/2". my pads in the area of the picture below are floating above the steel plates that they attach to about 3/4". do people add spacers there or did they end up setting directly on the steel pads? these are the pads that the outsides and corners needed trimmed down to allow the front end to move side to side.
    Doug
    Quote Originally Posted by dougkirkbride View Post
    Doug
    Hi Doug
    on most cars I've seen, the bumper site on the steel pads.
    A lot of us used a piece of aluminum angle to attaché the bottom of the bumper to the 1x1 steel tube.
    There is a 1/2 to 3/4 gap between the bumper and the steel.
    bob
    PS: stop by as you travel south for vacation.
    Feb 2013
    Bowling Green OHIO
    Thanks Bob, I will move it flush and put the buckets in.
    Next time I am traveling thru cinci I will look you up, would love to see your cars.
    Doug
    Feb 2013
    Bowling Green OHIO
    O
    Well, moved this connection flush
    and ran into a problem with the hood hitting my radiator cap....stuck a spacer in that to get the outlet away from the steering rack about 9 mos ago. bummer. i am finding this car has alot of the same issues the custom machines we build and install at work have. everything is designed with cad and 1/16" clearance on the monitor looks great when your zoomed into it
    guess I will try it with spacers, about 1/4 to 3/8" spacers there, this throws my points on fenders and hood up tight with the windshield, ughhh, more clearances somewhere would have been nice. time to trim some more...
    buckets arent in yet.
    Sep 2014
    Dallas, TX
    Hi Doug
    Great idea, I picked up a piece of aluminum angle for this purpose today.
    818S Chassis #288 2.5L 323hp
    joshuajach.com
    Massachusetts
    Bob. What is the name of the bolt that you glued to the inside of the bumper to hold the Z bracket that holds the headlight bucket? I see MMC has elevator bolts but the head is just a disk with a square section just under the head. Yours had holes in the disk.
    Thanks for the video.
    Davis
    Quote Originally Posted by CU9DZ View Post
    Davis
    Bottom of this page http://www.mcmaster.com/#catalog/121/3177/=ye9hwp
    Massachusetts
    Great Thanks. I followed your video and understand why you have to adjust the headlight up or down to get the best fit or for headlight beam alignment.
    Davis
    DFW, Texas
    Hi Doug
    bob
    Bob, Sorry to revive such an old post, but I was mounting my bumper this week and my bumper is sitting on the pads (up top), but the lower front part of the bumper is about an inch or so forward and 1/2 - 3/4" below the 1x1 tube.
    Is that what you used the aluminum angle for?
    The manual made it seem like the bumper and tube would be off by height, but not off by how far forward it is. I have the fenders clamped on the side sills and the front bumper, so I think my bumper placement is correct, but would rather cut once.
